Best way to mount video camera w/o a roll bar
I've got an '87 Carrera that I'm taking to the track on the 28th. I'd like to mount a video camera that I already own (Panasonic DV) but don't know how. The searching I've done here mostly involves people mounting it to a roll bar. Window suction cups don't seem to hold up. My car is completely stock. Does anyone have any ideas?
Thanks,
Scott
1988 Porsche 944 Turbo S 70,000
1987 Porsche 911 107k (sold)
1982 Mercedes 240D 4-Speed (mileage unknown)
1998 Mercedes E300 Turbodiesel 147,000 (sold)
1985 Mercedes 300D 227,000 (sold)
Old 07-15-2007, 04:59 PM
Mr9146's Avatar
I know Dan Byers uses a tripod and he bungees the HELL out of it so it doesn't move...
Old 07-15-2007, 05:10 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
I made a cross bar that mounts to the stock seat belt mounts on the B pillars. I used it to mount a camera ball mount that the camcorder can screw right in to. I used two pieces of square steel tubing with flat bar I welded onto the ends that I bent to match up with the mounting holes, and then a piece of angle steel in between them for adjustability and the ball mount. I can take a pic if you want. It was pretty simple to fabricate.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 07-15-2007, 05:12 PM
UFLYICU
ZOA NOM's Avatar
Here's some pics...
prc-racing.com
Old 07-15-2007, 05:23 PM
Thanks for the suggestions so far. Welding is a little out of my league. I like the tripod idea. I had never even considered that.
Scott
Old 07-16-2007, 05:36 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
In the professional industry..we use an item called a Noga arm.
It is a series of ball joints connected by lightweight bars or tubes.
They attach with either a 1/4-20 or 3/8-16 thread to a firm location and position with a single knob that tightens the whole unit at once.
Very easy to use, sturdy, and can be screwed into any convenient location.
Bob
Bob Hutson
Old 07-16-2007, 07:10 AM
Less brakes, more gas!
euro911sc's Avatar
If you have non-standard seats with head rests you can mount the cam to the passenger head rest posts. Pretty easy and you have a great view... provided no one is in the passenger seat I have seen this on some non-Porsche cars... Porsche Sport Seats, obviously, have no posts
Best regards,
Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 07-16-2007, 07:31 AM
GO DAWG GO's Avatar
Scott,
Got an Idea...Go to your local metal yard and buy a flat aluminum extrusion (6061 t-4) 2" x .125 (1/8) 6 feet long. Measure your "B" pillar seat belt loop separation dimension (Inside across). Form the ends radially to meet those points, Drill the 7/16 holes to mount on the seat belt loop hardware. Then cut a piece of "L" aluminum extrusion 2"x 2" ~ 4 feet long and attach it to the flat support as a stiffener. Rivet or bolt together and you have a light weight camera support like Zoanas with no welding and much lighter. Just a thought.
Bob
1 bad 930
Old 07-16-2007, 12:06 PM
