How to convert to single windshield wiper mode?
I saw this on another Carerra, only the passenger wiper was installed and it swept full 180 degrees, driver's side was deleted. Looked pretty cool, how is it done?
Old 07-15-2007, 10:54 AM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
I removed the passenger side and reversed the driver's wiper to rest to the passenger side. I don't think a passenger side wiper would reach to the driver's side. It would be so long it would stick up over the roofline.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 07-15-2007, 11:47 AM
Grappler
Rodsrsr's Avatar
I did the same thing, and it actually rained the other night. Works great.
Old 07-15-2007, 01:30 PM
Interesting...I did the same thing, but mine parks a good three of four inches higher in order to get a good swipe of the area in front of the driver. Did I do something wrong? ('83 SC.)
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 07-15-2007, 02:10 PM
AutoBahned
RWebb's Avatar
Jim Calzia used a 944 wiper & motor.
Old 07-15-2007, 02:20 PM
UFLYICU
ZOA NOM's Avatar
I use a 15" blade.
prc-racing.com
Old 07-15-2007, 03:30 PM
Has nothing to do with the length of the blade, I'm talking about where it parks. The one in the photo parks at about nine o'clock, when viewed facing aft. Mine parks at ten. Whatever length it is--I couldn't tell you without running out to the driveway in the middle of a thunderstorm with a ruler--it's just long enough to clear the top of the windshield and no more.
Stephan Wilkinson
Old 07-15-2007, 07:39 PM
UFLYICU
ZOA NOM's Avatar
Simply remove the nut holding the arm on and move the arm CCW.
prc-racing.com
Old 07-15-2007, 08:36 PM
jeff1hughes's Avatar
Re: How to convert to single windshield wiper mode?
I don't know if it is too easy on a Carerra. I believe it may have been a 993 you saw, or a Carerra converted to a 993 wiper system as they have both pivots closer to the centerline of the car, making it easier to get a near full wipe from a single blade.
86 Carrera Targa - Garnet Red Metallic
88 928 S4 - Gran Prix White
Old 07-15-2007, 09:02 PM
Zoanas, removing the nut and repositioning the arm isn't the answer. If I do that, the arm parks just fine but sweeps an area that goes from--here we're using "clock positions" as seen from the driver's seat--from three over to about noon and back to three, etc.
Stephan Wilkinson
Old 07-16-2007, 05:36 AM
DP935 member
kycarguy 935's Avatar
Here is a pic of the underside of a uni-wiper on a DP935. I am not sure if DP sells a kit.
Porsche Slantnose M505 M506 group on Facebook.
https://www.facebook.com/groups/719995181372494/
Old 07-16-2007, 05:48 AM
Work in Progress
Rich76_911s's Avatar
Here is an old thread about how Rdane did it on his car:
what`s the procedure for running a single wiper
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 07-16-2007, 06:17 AM
drl911's Avatar
The wiper motor has to run one revolution per wiper cycle regardless. The only way to change the total angle of wiper motion is to change the connection point to the crank arm which is connected to the wiper motor. I did this to mine and got the exact total wiper motion I was looking for. After that you can re connect the exterior wiper arm to the output shaft spline to fine tune overall positioning.
Dan
Can I ask you a question? Sure, what is it? An interrogative statement that tests ones knowledge, but that's not important now....
'86 Carrera . . . '87 951 destroyed by drunk driver ... '01 Boxster S. . . '04 Cayenne S . . .
Old 07-16-2007, 06:26 AM
Excellent! That's the answer I was looking for. So you make a connection point closer to the axis of rotation, which makes sense.
Stephan Wilkinson
Old 07-16-2007, 06:34 AM
drl911's Avatar
It does not take much. I think what I actually did was cut the crank arm (the one connected to the wiper motor) with an abrasive wheel so it removed about 1/8"~3/16" of material. Then I just butt welded it right back together. The net effect was that it was shorter. With a little thought someone could do a kinematic linkage diagram, but I just went with a simple ratio change and some gut feeling.
Old 07-16-2007, 06:41 AM
UFLYICU
ZOA NOM's Avatar
I bent the wiper arm.
prc-racing.com
Old 07-16-2007, 08:59 AM
rw7810's Avatar
question On option 2:
to remove the passenger side arm and lengthen the driver's side blade to 19 in., doesn't it hang over the edge quite a bit on the drivers side while it's in motion ??
Robert Williams
70' 911T
Old 07-16-2007, 11:40 AM
