hi. i'm removing my injectors from my 3.2 and installing them on an other 3.2 manifold. my question is the seal kit that i got for the injectors don't look like the old one and i'm not quite sure how to install the new kit. has anybody done this? thanks
I have replaced my o-rings with the replacement sets. There are more parts in the little bag than you will actually be using for the 3.2 injectors. Out of the pack, it is just the two o-rings that are changed out. The little plastic "hats" stay in the bag, not used. You should have two o-rings, one goes on the top, the other on the bottom. Be sure to lube them a little before installing. Hope this helps. Good luck!! Tony.
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
thanks Tony for the help. that's what i thought as well. thanks
That's great!! I am glad if I was able to help, Tony.
