PMO Carb help...dyno graph inside
Car is a 914-6 built by Zotz Racing...2.5, Equal Length headers, PMO carbs, Electromotive XDI (Locked at 28degrees as per Zotz) Race gas...
We are having a very hard time eliminating the lean condition in the upper rpms. Anyone have any suggestions as to what jets and emulsion tubes to run?
Right now we are running -
185 Fuel
190 Air
F16 Emulsion
and this is the result -
Thanks!
Excell Racing
Boca Raton fl
Old 07-18-2007, 07:12 AM
81 911 SC's Avatar
I'd call Richard Parr and PMO and discuss with him.
- Tyler
1988 911 Carrera Grand Prix White/Black
2015 Cayenne Diesel Black/ Luxor Beige/Black
Old 07-18-2007, 08:47 AM
Elombard's Avatar
Fuel Pressure?
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 07-18-2007, 09:54 AM
JW said F3 cause fuel mix to run very rich way up high.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-18-2007, 10:02 AM
North Coast Cab's Avatar
SSETEK,
I have the same issues with my PMO's.
I started here:
Main Jets 150
Air Jets 180
Emulksion F11
I changed per Richard Parr to:
Main Jest 140
Air Jest 170
It didn't change anything. I run the HPV-1 ignition and was thinking about going to the XDi2, but if you are having the same issues I may hold off on that.
John
1985.5 944 GTS
Old 07-18-2007, 10:04 AM
Porsche Doc's Avatar
Change your air jets down to the 165-170 range.
That will raise the fuel higher into the emulsion tubes.
Get on the dyno when you do it. But you will have to just experiment to ya get it right.
We use F11 tubes aswell.
Good Luck Man
Thanks!
Don Ramsay E Mail: aircooledclassicsporsche@gmail.com
The father of 964 Backdating!
www.aircooledclassics.co
www.facebook.com/AirCooledClassicsPorsche/ www.instagram.com/aircooledclassicsporsche/
Old 07-18-2007, 10:31 AM
Don, thanks for the advice, I will see what we can do.
John, let me know if you make any changes and they help!
Excell Racing
Boca Raton fl
Old 07-19-2007, 06:05 AM
shbop's Avatar
signing-up
Jon
Old 07-19-2007, 07:54 AM
PMO
Did Zitza dyno that engine ? we do most all of the dyno work for Zotz, If not give me some more info on your engine set up and I can help, e mail me if you like Brunsmspts@aol.com
Thanks, Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 07-19-2007, 08:52 AM
Thanks to everyone who has offered help!
We are working with Mike Bruns, who has been great, and hopefully we can fix the issue.
I will keep you all updated.
Excell Racing
Boca Raton fl
Old 07-27-2007, 05:53 AM
