Poll: What is the best Engine Management System?
Poll Options
David's Avatar
Originally posted by herman maire
Would a M48 system been enough for your car? I thought the M600 was expensive almost overkill for a street car because it had fancy features like
-ignition cut out for sequential gear boxes
- traction control
- Data loging ect...
features not needed on our old cars.
the M48 is only like $2400 also... not to bad if it does the job.
I think most people still use the M48 even on high end projects, I used the M600 for the additional ignition outputs, but it could be done cheaper with an ignition expander.
Old 07-20-2007, 08:06 AM
