Please tell me what this part does????????
Carrera 3.2 1986 Euro spec. UK reg. car
I'm thinking the part is a vacuum hose for the power brakes, I've been stripping the inlet manifolds off to replace the gaskets (3 out of 6 had "sucked in" ) and I noticed the rubber connector on his pipe had perished. Obviously I'll replace the pipe ($145 ouch), but I'd like to know its function, my Bentley manual doesn't seem to mention it. http://www.pelicanparts.com/cgi-bin/smart/imgdsply.cgi?pn=93011032803-M100&html=Y Thanks in advance Mark
'85 Carrera 3.2 Coupe |
That's what I heard as well. Instead of paying for a new line, can you take it to a hydraulic shop and have them put a new hose on? I replaced mine, only to find out later, that a lot of guys have theirs repaired for a lot less.
Dave
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Thanks for the advice Dave, I'll take it to the local hose shop tomorrow. What I wondered was if it is a vacuum hose and is sucking in air, was this contributing to my engines rough idle? What symptoms did your spilt hose give?
Mark
'85 Carrera 3.2 Coupe Last edited by mhinch; 07-23-2007 at 03:55 PM.. |
Friend of Warren
Yes, vacuum line for your brakes. Mine was cracked and I wrapped it in some of that self-sealing rubber tape. Held up for 3 years now.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Dave
Got the hose repaired yesterday, job sorted
cheers guys
Cool and probably for less then buying new one! I did keep my old one and plan on getting it repaired one of these days. Dave
a short piece of heat shrink tubing takes care of that real cheap.
Does the cracked hose can produce engine misfiring?
Author of "101 Projects"
It shouldn't. This is simply a conduit for vacuum. The reason why it's mostly metal is so that it doesn't collapse on itself. When I did the Super Boxster conversion for the Boxster book, I used standard "vacuum hose" that collapsed on itself. It still worked fine, but it certainly doesn't look like it should work as well. Power brakes work fine though. Still, this on the "replace eventually list..."
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
