Help !! No reverse
Got home today after taking the 930 for a short drive, and VOILA.... can't get it into reverse.
.... it's not making nor did it make any noises, but when I shift to where reverse is SUPPOSED to be, it's in first..... someone please tell me this is a simple fix ![]() Thanks, Jer
86 930 Turbo Guards Red / Black |
one of gods prototypes
linkage adjustment at the coupler? 930 reverse is left and forward i take it?
Brought to you by Carl's Jr. |
Yes, it is left and forward....is there some way I can check this without disassembling anything ??
You have no reverse on a 930. What is a little disassembly for peace of mind? I ask this not be condescending. Call it personal experience. You must inspect the shift bushing and the clutch cable. These are the easiest fixes and likely causes. Our host supplies diagrams for the assemblies as well as articles for adjusting the shifter and the cluch.
BTW since it is a 930 and reverse is to left, the adjustment procedure may need to be reversed. Perhaps someone else can confirm this. Also, keep in mind when diagnosing that reverse has no synshro. I halways just bump the top of second gear before shifting into reverse on my 930. This assures that things stop moving before shifting.
cycling has-been
The same thing happened to me after a DE session in the 930.
I crawled under the car and adjusted the slack out of the clutch cable and it went into R with a lot less grinding. But I'm still not convinced I've totally solved the problem. Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
