Chirping Sounds Driving Me Nuts!
Does anyone else have soft chirping sounds coming off, what I believe, to be the brakes, at low speeds? I have a '79 SC with just 56K miles on it. Will just the length of time, the age of the car, take the tension out of the caliper springs? Is there something else that could be causing these noises?
'79 911SC Coupe We may be lost, but at least we're making good time... |
Hi, you could try putting a light chamfer on the leading edge of the brake pads, or try changing the make of pads. Some mechs put a thin layer of very heavy grease (or copper grease) between the pistons and backs of the pads, it's supposed to make a difference....eliminates wind noise or something. I've never found a cure, sometimes they do sometimes they don't ...seems weather dependent.
BTW, original pads are no guarantee that they won't squeak or squeal. Cheers, Mike
Evolved
Caliper Springs? Brake wind noise? I need to read more! My knowledge of brakes is really lacking something???
Don't fear the reaper. |
Somatic Negative Optimist
Open the Bentley SC Repair Manual, read from 460-1 to 470-11 and you'll understand a lot more about your brakes.
Lift the car securely, take the front wheel off, press the pads open with large channel-lock pliers, remove the pads (Make sure they move freely in the calipers, file if necessary) check the 20 deg cutout alignment on the pistons (460-6) Check the dust boots. If everything looks good, smear some brake goo between pistons and the back of the pads, clean everything an reassemble. Pay attention to the pistos. If they are seized, or don't move freely, it's time for a rebuild. This is the time to check/adjust play in the front bearings and top up the grease inside the Stouffer cup.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
This Way Up
Does the noise occur when you are on the brakes or just at low speeds? I get some chirping going over bumps at very low speeds that I believe could be due to worn suspension bushings - but I haven't looked into it yet to confirm.
OK here's a possibility..........
I had the same symptom - loud chirping noise when driving - seemed to be in the suspension or a wheel bearing - couldn't pin it down. Finally I figured it out, it was the dash blower motor bearings. As soon as I'd hit a certain speed the fresh air coming through the cowl inlet would cause the blower fan to rotate at low speed even though it was not on - causing a chirping that seemed to come from outside the car. I figured it out by turning the fan switch to high - and the noise stopped. Turning off the fan resulted in the same chirp coming back as the fan slowed to a stop. I've yet to take it apart and lube/replace the fan bearings, but I no longer wonder if a wheel is going to fall off. Ron
1996 993 Coupe, Tiptronic, Polar Silver 1973 914 1.7 Marathon Blue Metallic - Sold 1977 911S Targa - Sahara Diamond Metallic - Sold 1975 911S Targa - Copper Brown Metallic - Sold |
I has a squeaking noise once for a few weeks, but it was a gerbil I forgot about
-Todd '82 911 SC Coupe w/'92 3.6L, bulletproofed 915/62 w/GT LSD & Wevo goodness, Rennsport RSR/Bilstein Sport, SRP ARB, ER Polybronze, BK strut brace, 15x7/8" Fuchs. Sold: 92 964 Turbo, 81 SC, 96 993 Coupe, 82 SC, 89 Carrera Cabriolete |
Make Bruins Great Again
Make sure you don't have a frozen caliper.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
I had the same chirpping that was driving me crazy for years until I jacked up my front end one day and found my left front A arm was loose up front where the three 17mm bolts were just hanging on their inserts that had broken off.
Take a look at the illustrations on this thread and you might see how one of the 17mm inserts has broken off it's welds which is pretty common since they're only tack welded at two points. Any lowered 911 that has bottomed out on the front A arm cover has probably broken some insert tack welds. Ran over curb; front end damage Cheers, Joe Last edited by stlrj; 06-22-2007 at 09:49 AM.. |
Clear here: Ran over curb; front end damage ![]() Does anyone know the torque spec?
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
That chirping ain't not swallow...
I have determined the chirping to definitely be coming from the brakes. When I hit the brakes the chirping stops. When I release the brakes the chirping is gone for a minute then returns. I hit the brakes again ant it stops. Could my brake pads be glazed? What else might cause this? Thanks. -O.K.
You do not have permissi
There could be a little runout in the brake disk-fixed by getting them turned.
Is there any resistance in any one spot while spinning it? Wheel bearing/ball joint play?
Meanwhile other things are still happening. |
Like someone here said, it is likely the slight amount of backlash that is taken up when you apply the brakes ( and no squeal) vs. when free-running and you hear the squeal. Some folks use the brake pad "goo" that gets applied to the backside surface of the pad before you re-install...but I've found these messy and tends to take out the dust boots later as you remove old pads. I usually do a couple of things that tend to help.
- chamfer the edges at a 45 degree angle ( slightly, don't go nuts) with a file or rasp. Do all sides. Make sure the 20 degree caliper puck orientation is correct. - add "anti-squeal" shims made of an Aluminum/acrylic composite, and has a one-sided adhesive that allows it to stick to the backside of the pad. I found this usually as a "Help !" product line from Colmar, Pa...found at your FLAPS. If you're lucky you can find this cut-to-size for your particular brakes but I've lately only found the big sheet that you cut up with a scissor. Works well.... - Wil |
