Starter 10mm Barrel Nut part number???
Anyone know the part number for the 10 mm allen/barrel nut the holds the starter on. This is an 84 application but I think they used it for many different years. (Yes I lost it).
Thanks in advance, paul
If you aint breakin' it, you aint racing it hard enough! 1974 911 3.0 Euro Sahara Beige/Black |
Hi Paul,
I believe it is the same as the cylinder head barrel nuts, 10mm, 901 104 382 02. I haven't found the starter nut in my parts catalogs. edit: Confirmed cylinder head barrel nut, 10mm, 901 104 382 01 or 02.
DOUG '76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's. '85 911 Carrera, stock, just painted, Orient Red Last edited by 2.7RACER; 08-07-2007 at 10:22 PM.. |
Doug is correct, same part number as a cylinder head barrel nut.
One may consider a flanged nut for replacement as getting at in the future is much easier with a hex head flange nut. Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
