Just sent you few docs that should help you figure out the ICV issue. If the ICV does not hum vibrate with key in RUN engine off you have an issue. Could be the valve, the wiring, the DME or a combo of either of these.
If possible test the valve in another 84-89 Car, very easy to do just plug it in and see if it hums in the other car. No need to install it in the test car, just wire it up. NEVER use any other valve other than Bosch! Quote:
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
https://r.tapatalk.com/shareLink/topic?url=https%3A%2F%2Fforums%2Epelicanparts%2Eco m%2Fshowthread%2Ephp%3Fp%3D12031768&share_tid=1142260&share_pid=12031768&share_fid=844&share_type=t&link_source=app [quote name="wazzz" post=12031459]Others will probably shime in and confirm or not, but I think you should indeed see pulses on both sides. So if one side is dead, this might be the sign of a dead transistor inside Motronic. One of the ON588 Darlingtons referred as T560 or T561 on the schematic. I have a scope and an 88 Carrera. If I find time today I'll check it and report. What's the frequency of the square signal?[/QUOTE]Hi, I scoped both together versus the engine as ground, it shows 0.5V pulses on one and not on the other. I was hoping to check it at over- and under- revs, to see if the other started showing a signal but before I could the engine speed started fluctuating wildly. I suspect the ICV piston was oscillating within the valve. ![]() Sent from my SM-G988B using Tapatalk Sent from my SM-G988B using Tapatalk |
What's the idle valve signal look like?
Dave Last edited by mysocal911; 06-27-2023 at 11:09 AM.. |
Then you can properly probe the two outputs without the connector on the valve.
Dave |
This reply here:
https://forums.pelicanparts.com/showthread.php?p=12031881 Sent from my SM-G988B using Tapatalk |
Good luck.
Dave Last edited by mysocal911; 07-01-2023 at 03:37 PM.. |
