Fast turn signal
Hello My fellow Porsche owners,
I have a fast left turn signal and the front light works but does not blink.
I have a new bulb and relay installed.
Can anyone think of something else.
Old 08-09-2007, 07:13 AM
Driving member
jester911's Avatar
Usually one of the bulbs is out when it blinks quickly. Either front or back.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 08-09-2007, 07:15 AM
abit off center
cgarr's Avatar
Check the grounds
______________________
Craig
G2Performance
Old 08-09-2007, 07:16 AM
kplackmeyer's Avatar
Be certain you have the proper bulb in there. Sounds silly, but I have seen a 2 filament bulb in a single filament socket, and vice-versa. Can make all kinds of weird things happen.
Kerry Plackmeyer
1975 911s
Old 08-09-2007, 07:20 AM
pmajka's Avatar
If you have replaced the bulbs, check the thin wires in the head light buckets for corrosion or connectivity..
happens every time i pull out the head light.
Have you ever felt suffocated while watching the Oxygen Channel?
People with excuses fail. As soon as I OK my actions with an excuse, I cease bettering myself.
88 Carrera
Old 08-09-2007, 08:16 AM
Slumlord
Porsche_monkey's Avatar
Check that your bulbs are not low-wattage. The circuit will not work with the low wattage bulbs because the coil needs a minimum current to operate properly.
Do search, but I think low wattage are 15watts and you need 21 watt bulbs.
Also, you should specify your vehicle and year in your signature, or in your post. If you have a 1977 Lada my advice should be ignored.
Old 08-09-2007, 09:04 AM
