Engine removal issues
A few weeks back my rubber centered clutch disk gave way and I am now in the process of repairing it. The problem is that I can't get the engine and transmission seperated. I am pulling the engine only and everything is disconnected including the shift linkage and clutch arm pin, and I still can't get the two apart.
I fear that some debris from the clutch may be wedged in there making it difficult to get the engine off the transmission. Any ideas? I am contemplating removing the four studs to free the engine a bit. Thanks, Bob |
Engine/trans Separation.....
Bob,
Have you removed the clutch positioning lever? This controls the shaft that hold the clutch release fork. It is a lot convenient to remove/install the trans and engine bolted together IMHO. Tony |
Make Bruins Great Again
What Tony said + you really have to work on it to get the two apart. I just did mine and we had to pull and "twist" it side to side to get it to work loose.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
be careful with the clutch lever spring...sucker is wound up tight
Porsche-Less at the moment.... |
Did you remove the clutch release fork or is that the clutch arm pin your talking about? Take the engine and tranny out together. I played the same game my first engine drop trying to remove just the engine and I'll never do it again. Once I had the two out together they came apart a lot easier. Same going back in, easier as one unit. Good luck
1987 911 Coupe-Current ride 2007 997TT-Sold 2006 997 C2S-Sold 1991 964 Turbo-Sold 1987 911 Targa-You never forget your first |
Thread Tools | |
Rate This Thread | |
