wannabee wannabee
WIL84911's Avatar
how do I find out if my 84 has front or rear oil cooler
need this info for installing SSI's. I'm guessing my 84 has rear oil cooler but not sure.
99 C4 - (let's try this once more)
07 Cayman S - sold 11/17 (not the same)
84 Carrera - sold 3/16 (geez what have I done!)
Old 09-05-2008, 01:09 PM
TroyGT's Avatar
If it's the original engine then yes... the big Z shaped rubber hose located under the right rear of the car has one end connected to the oil cooler and the other end to the oil tank.
-Troy
1986 911 Coupe (Guards Red), Fabspeed Euro Pre-muffler,
Steve Wong Performance Chip
2001 Boxster 2.7L (Orient Red), bone stock
Old 09-05-2008, 01:22 PM
Stock it has both.
Rear, on top of the engine on the R side.
Front, in front of the RF wheel.
Old 09-05-2008, 01:36 PM
If you're installing SSI's, the oil cooler lines need to be backdated to pre-'75 configuration. You will have to replace the two lines currently on your car with the two lines in the attached photo. Hope this helps.
Mike...
'84 Carrera Targa (3.0 with SSIs, Webers, DC-19 Cams, MSD) - Sold
Old 09-05-2008, 02:43 PM
wannabee wannabee
WIL84911's Avatar
Thanks! Sorry for the delay.
Old 09-21-2008, 04:17 PM
