wannabee wannabee
how do I find out if my 84 has front or rear oil cooler
need this info for installing SSI's. I'm guessing my 84 has rear oil cooler but not sure.
99 C4 - (let's try this once more) 07 Cayman S - sold 11/17 (not the same) 84 Carrera - sold 3/16 (geez what have I done!) |
If it's the original engine then yes... the big Z shaped rubber hose located under the right rear of the car has one end connected to the oil cooler and the other end to the oil tank.
-Troy
1986 911 Coupe (Guards Red), Fabspeed Euro Pre-muffler, Steve Wong Performance Chip 2001 Boxster 2.7L (Orient Red), bone stock |
Stock it has both.
Rear, on top of the engine on the R side. Front, in front of the RF wheel. |
If you're installing SSI's, the oil cooler lines need to be backdated to pre-'75 configuration. You will have to replace the two lines currently on your car with the two lines in the attached photo. Hope this helps.
Mike... ![]()
'84 Carrera Targa (3.0 with SSIs, Webers, DC-19 Cams, MSD) - Sold |
wannabee wannabee
Thanks! Sorry for the delay.
