CMXI's Avatar
Replacing shocks/alignment
Do i need to do a alignment after replacing just the shocks on a 84 carrera??
My guess is that i wont change the suspenson setting by replacing the shocks..
Am i right??
Track day car: 911 3.2 915 Black 1984
Daily driver: 911 3.2 G50 Blue metallic 1987
Winter car: Volvo XC90 2003
Old 08-13-2007, 11:05 AM
durn for'ner
livi's Avatar
I didnīt. But then you will probably here opposite opinions too. That for example installing new gas shocks instead of the old hydraulic ones, the ride hight will change to a degree it will affect the alignment. Generally I do not think just changing the inserts will matter much.
Markus
Resident Fluffer
Carrera '85
Old 08-13-2007, 11:35 AM
CMXI's Avatar
Im just thinking that eaven if the rideheight is affected, by adjusting the rideheight to the same height as before i should have the same settings!
Old 08-13-2007, 11:54 AM
durn for'ner
livi's Avatar
Thatīs what I thought too. As a precaution I had an alignment done afterwords (I upgraded to the turbo tie rods at the same time), and it was spot on. But maybe I just got lucky.
However, I did not touch the rear ride hight. Too intimidating for me. It does sit a little high to the eye, but as I said the alignment was perfect.
That said, changing inserts hardly did anything to my ride hight. Maybe 5-10 mm.
Markus
Resident Fluffer
Carrera '85
Old 08-13-2007, 12:00 PM
It's not a bad idea to check your alignment periodically regardless.
Joe
Old 08-13-2007, 01:25 PM
