What is a good rust prevention spray for hardware?
I'm looking to keep steel hardware looking nice and keep it easy to disassemble down the road. I've traditionally used WD-40 for this but am wondering if you guys know of something better?
I'm not looking for anti-seize, cosmoline or undercoating....just something to spray-on pre-assembled hardware to keep it fresh.
'83 SC |
19 years and 17k posts...
I use Gibbs Spray lubricant/protectant (www.getgibbs.com). WD-40 is a water dispersant and really doesn't provide the lubricating qualities people are looking for. When reassembling nuts/bolts, etc... I use copper anti-seize paste on the threads.
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
Sultan of Sawzall
I've had good luck with Gibbs and Boeshield T9
http://www.theruststore.com/Boeshield-T-9-12-oz-Aerosol-P3C4.aspx
Gruppe B #319 2 '86 911 Carrera coupes (red & white) '66 Corsa convertible 140/4(red) '66 Monza coupe 110/PG(white) '95 993 cabriolet (wife's) |
3rd on Gibbs
Robert Williams 70' 911T |
Corrosion resistance
I'm using a spray product called "So Sure", that I got (free) from my cousin who is a former Coastie. Made by LHB Industries, which is a government contractor. Website, http://www.lhbindustries.com/lhbstore.htm, case is $111, which is probably 2 lifetimes worth of product for me. Not sure if they ship to a residential address.
It sprays out as a liquid, then sets up as a clear semi-flexible coating, almost like a heavy laquer. Once dry, the coating will abrade, and is not meant for fittings to be lubricated, or to be used under a lubricated surface. It is primarily meant for exposed hardware or surfaces. I'm using it on some zinc hardware under the car (that can't readily be seen), and I sprayed my banana arm bolts with it. Also used it on the soft metal brake line pipe from res. to the master cyl. Hey, if it's good enough for a destroyer, it should help my 911. FWIW: there's Boeshield, made by Boeing. It's probably the closest thing to Grady's "Techtyl" that is available in spray cans in stores and online, without having to buy 1000 gallons at a time. Boeshield is supposed to spray out as a liquid/lubricant, then sets up as a waxy coating. I might have to buy a can for my torsion bar tube. What do you think guys?
Lps3
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
