Wash. State
nesslar's Avatar
Importance of spare DME relay....
Well, it happened, just as you helpful folks have always maiintained it would eventually. So glad I listened to your sage acvice...........I stand in due respect of all your expertise and knowledge. Cheers!
Thursday I dropped my son off for baseball practice, and while I was getting his bag of things out of the trunk (that's up front, you know! ) my '86 Carrera, while idlling in place, "coughed" once, sputtered for just a half-second, then ran just fine. On the way home I stopped at a convenience store and NO START upon wishing to leave for home.
I tried and tried, but the thing just kept turning over but not firing up. I waited between starting attempts, and finally, after a good 30 minutes of anxiety, it roared to life. All this while some drunk 'bastige' kept telling me he'd gladly push me with his truck! I drove home and put her in the garage.
Saturday morning the car fired right up and I pulled out and parked in the driveway, warmed the car up partially, then shut it down. Later, intending to run a few errands, I hopped in, and once again it wouldn't start, only this time, no way was it going to start.
I pushed the deceased (only comatose actually) into the garage and told myself "Self, it's time to see what little bit you can do to revive a 911."
I fought with the existing distributer cap and replaced it along with the rotor (they really needed changing, looked original) to no avail. No start.....
After feeling somewhat deflated for a little while, I researched exactly where that pesky DME relay was located and decided to try replacing that, too. Fortunately I had recently bought all these things!
Well, under the driver's seat (no need to remove it of course), two little coverplate screws and a nut later, after plugging in the new relay, VRROOOMM! Yes! fixed it! Mind you, I'm no mechanic, and I didn't stay in ANY hotel/motel the night before, but I did shoot 31 on the front nine yesterday morning! Whoa!!!! And then I birdied no. 10!!!!!!! It became a REALLY good day once the 911 came back to life.
Do those relays usually just die immediately, or do they sometimes take a day or so to completely croak? Also, BTW, the old relay was "loose" inside and would rattle when shook! Surely that ain't right!
Thanks to all the helpful info out there, people! And keep a new spare DME, for God's sake!
Old 08-13-2007, 08:22 AM
Now go get thee another spare and drive!!!
Old 08-13-2007, 08:42 AM
Wash. State
nesslar's Avatar
Right on! Will have a new Pelican Parts DME relay on its way asap!
Old 08-13-2007, 08:53 AM
19 years and 17k posts...
azasadny's Avatar
Excellent!!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 08-13-2007, 09:03 AM
i love reading success stories like this one!!! Excellent work!
Old 08-13-2007, 09:55 AM
dshepp806's Avatar
yes,..get that new spare DME quickly..
Best,
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 08-13-2007, 03:06 PM
Make Bruins Great Again
Por_sha911's Avatar
Someone gave me this wise advice:
Not only should everyone have a spare but they should swap it out once before they need it. This will a) tell you that your new spare is good and more importantly, b) you will know how to do it before you are under pressure to replace it on the side of the road at night!
Joe
Old 08-13-2007, 03:19 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
Yes, the DME relay (as most relays with soldered connections) will die a slow death, with sometimes different symptoms, since it is actually two separate relays in one. Half provides voltage to your fuel pump, and half sends voltage (current, actually) to the injectors.
Well done.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 08-13-2007, 04:22 PM
glory to (a) Ferdinand Porsche, (b) Norbert Singer, (c) Robert Bosch, (d) Ferdinand Piech, or (e) the diety of your choice.
Congratulations, that is a good day for sure!
Old 08-13-2007, 05:31 PM
Great story! I've had similar experiences with my older BMWs. I think the DME relay is for a Motronic system, true? Is there a similar critical relay that SC owners should have as a spare?
Mike
Old 08-13-2007, 07:11 PM
rootmatt's Avatar
Now, if only this forum could be linked to our host's mighty part supply system. A new relay could be sent out automatically. Over the top?
Matt
1982 911 SC coupe RoW
moss green
SSIs and M&K 2-1 muffler
Old 08-13-2007, 07:56 PM
Early_S_Man's Avatar
Porsche Crest
Steve W. posted a discussion about resoldering the failed relays ... you can use you old one as aspare then ...
DME Relay failure - Prevention and Repair
Here are close-up pics:
PICS - Failed DME Relay
More pics and discussion:
http://forums.pelicanparts.com/showthread.php?threadid=185563&highlight=dme+relay
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 08-13-2007, 11:47 PM
Wash. State
nesslar's Avatar
Quote: "Not only should everyone have a spare but they should swap it out once before they need it."
Exactly what I intended to do! I purchased the new relay only recently, and sure enough the original croaked before I swapped them. Actually I think it's a better idea to have TWO good spares always, because as in my case, the old one was ready to die! Had I used it as the spare, I could have experienced two failures within a short time eventually, maybe while on a drive out in the sticks somewhere!
I think I'll also check into repairing/soldering the old one if it looks salvageable and then test it. Cheap spareand a good little project. Still, another new one (at least one) is on the list.
As for an SC needing something similar, I have come to expect that since those cars are "Super" (somethings) they surely aren't in any kind of danger of becoming a roadside attraction for towtrucks......
Old 08-14-2007, 06:53 AM
Por_sha911's Avatar
I just tested the new one and then took it back out and put it in the glove box. When the original died, I did the same thing when the next spare was delivered. As far as repair is concerned, no one has suggested it but I'm wondering if its worth the risk since the cost is minimal and a broken solder will stop you dead in your tracks.
Joe
Old 08-14-2007, 02:56 PM
dshepp806's Avatar
the broken solder joint is a dead failure for sure...one must look for this.....make sure all is well in the connectivity world..amen!
best,
Middle Georgia
Old 08-14-2007, 03:41 PM
Venetian's Avatar
It is good to note that the new relay can be faulty as well. I replaced mine with a new one from Pelican after purchasing the car just "to be sure". It failed and left me stranded(similar symptoms as above). I automatically assumed it must be something else since the DME relay was brand new. I managed to get the car to a porsche garage . The mechanic reinstalled the old relay and all was well. Pelican replaced the faulty relay however the mechanic charged me about $100 for his diagnosis.
1987 Carrera, Venetian Blue.
Old 08-14-2007, 07:25 PM
