-   -   replace rear windshield (http://forums.pelicanparts.com/porsche-911-technical-forum/362428-replace-rear-windshield.html)
stevepaa 08-17-2007 09:14 AM
I plan to replace rear windshield this weekend. I have done this before on my BMW2002. But does anyone have a tip on where to start the rope pull on a 911 , top, bottom , corner? thanks
FinallyGotOne 08-17-2007 09:33 AM
I have heard to just be VERY careful at the passenger side bottom window area where the defroster wires are plgged in, very tiny and easy to bust.
Superman 08-17-2007 11:04 AM
I have been told that rear window defrost wiring is a huge PITA. I'm not entirely sure why, but everybody who understands this procedure says those wires make this job highly difficult.
Without those wires, of course, you would rope the gasket so the rope overlaps at the bottom of the unit. The bottom center gets roped in first.
stevepaa 08-17-2007 12:02 PM
Thanks, Jim.
Ron.G 08-17-2007 12:04 PM
The hard part is getting the wires in the seal where they belong and staying there. after you get that down just lay the window in the opening and then route the wires through the hole in the drivers side parcel shelf.
Of coarse you should have your rope or wire installed around the seal before placing it on the car. some soapy water on the seal is a good thing.
Put the bottom of the window in the lower channel FIRST and check the side to side alignment. then rope it in from the top. Have someone hold the bottom of the window to keep it from popping out if you have help. They can apply a little inward pressure to where you are pulling to help the window into the channel.
Other than the defrost wires, it goes rather easly. The reason to put it in at the bottom first is that you want the seal to lay against the sheet metal nicley up by the roof vents.
Use a dull dental pick or a butter knife wraped with electrical tape to fix any little seal folds ect.
Superman 08-17-2007 12:13 PM
Interesting. When I have seen front windshields done (twice), the rope ends are on the bottom. The bottom of the seal gets pulled in first. Perhaps the opposite is true of the rear glass, but gravity works on rear glass the same way it works on front glass.
Turboo934 08-17-2007 12:24 PM
I'vve done 300 over the years. Rope starts at the top.
mjshira 08-17-2007 12:29 PM
where can I get one? I need to get ride of that nasty third brake light on my 964 and want a normal rear glass piece to replace it...
Superman 08-17-2007 12:34 PM
Why?
stevepaa 08-17-2007 12:35 PM
James, got mine from local dealer $700 plus tax. I ordered the European version of the glass without the brake light.
Formerly Steve Wilkinson 08-17-2007 01:31 PM
You're crazy to eliminate the CHMSL these days. I not only installed one on my '83 SC but have two mercury-switch-activated LED brakelights (total of eight lights) on the underside of the rear wing. First time you're rear-ended the way my wife was in her totaled Boxster--by some distracted moron in an Excursion--you'll regret having let style overrule commonsense.
Not that a CHMSL will prevent rear-enders, but every little bit helps.
stevepaa 08-17-2007 01:35 PM
Actually, although I am eliminating the CHMSL, I am adding the basket handle and will alter it to do that fancy blinking action when I stop. The CHMSL just blocks my rear view too much.
mjshira 08-17-2007 01:45 PM
I am not getting rid of it, just going to a more slender one which will give me more rear view visability. At present I find myself moving my head to see around it...
700 bucks sounds steep! was there a part number?
Turboo934 08-17-2007 02:04 PM
Superman
The glass is narrow at the bottom.
stevepaa 08-17-2007 03:47 PM
964-545-107-04 regular
964-545-107-05 with brake light raised
964-545-107-06 with rear window wiper
964-545-107-07 with rear window wiper and brake light raised
964-545-107-08 Carrera RS (thin)
mjshira 08-17-2007 03:58 PM
I assume by 'raised' you mean with the black outline for the third brake light and rear defrost?
roger's 2937 08-17-2007 04:15 PM
Just finished having a rear window installed in my '84 Carrera and the wires need to be threaded into the rubber seal thru small holes in the correct locations. This was done by using a leather hole punch and on the driver's side you need 4 holes to thread the wires down into the engine compartment. By doing the holes in the seal in the proper location you get a nice even fit and you cant see the connections. The rope was also started and ended on the bottom of the glass.
Hope this helps-Roer B.
http://forums.pelicanparts.com/uploa...1187392471.jpghttp://forums.pelicanparts.com/uploa...1187392492.jpg
stevepaa 08-17-2007 04:15 PM
rear defrost is all on the windows.
brake light raised means CHMSL.
Superman 08-17-2007 04:16 PM
Not to beat a dead horse, but I still don't know why the roping does not start at the bottom. I don't know why the narrowness of the glass at the bottom would make a difference. What I do know is that gravity will be trying to lower the glass while you're frigging around with the roping beginning at the top. It seems like you might need someone to help fight gravity by pushing the glass somewhat upward so that you don't find it has sagged when you get to the final roping part at the bottom.
German engineers used gravity when they placed the oil tank well above the engine oil pump. Front glass is seated at the bottom first. Why not use those same principles on rear glass?
mjshira 08-17-2007 04:19 PM
all the prices for these are about the same... strange
