I have a 81 911 that started out life as a Targa. At some point in its life it was converted to a convertible. Up until a few weeks ago the top retracted flawlessly. The other day when I went to lower the top the motor on the passenger side would not release the latch. The drivers side will release and raise about 4 inches before stopping. The motor is held in place by 4 bolts. After removing them I could not remove the motor. There is what appears to be some type of set screw on the motor. If I back this screw out will it relieve the pressure on the gears and allow me to raise the top manually on that side? Summer in Wisconsin is to short and I sure could use some help.
Thanks Keith ![]() |
Back in New England!
Keith,
There is a screw/bolt that will allow you to manually operate the top, but I'm not sure which on it is. I recommend that you look on the parts diagram for the top's motor, it is labeled as such. Aside from that, someone has got to know. My top doesn't have the motors, so I don't know from personnal experience. -Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip! |
