factory shop manuals
Does anyone have a set of the factory shop mamnual for a 88 911? on CD would be better. Or if possible just scan all the body/chaasis alignment spec's
I really need the upper front specs now. A fellow bird sent me a copy of the manuals on CD but it was damaged in shipping(lost his info). Please help TD |
Friend of Warren
Not sure, but I believe the Bentley manual has these specs.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Work in Progress
You should be able to find the information you are looking for in this thread:
DIY Home collision repair
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB -Marine Blue '87 930 |
bump
somebody must have these spec's |
HI which info do you require?? is it this?
![]() ![]() ![]() this is from the 72> manual. regards mike
Regards mike 1983 911 SC sport, 1982 mini city |
Autodidactic user
TD,
Like our British friend, I'm not sure what you are looking for but perhaps one of these spec sheets will help. ![]() From the Porsche workshop manual 911 Volume V, Section 4, Front Axle (1980) (posted here for educational purposes only) or ![]() From the Porsche workshop manual "Body Repair" Section 3 (1979) (posted here for educational purposes only)
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions. ![]() 1973 911E Targa (MFI) |
specs
thanks guys
what I need is the top down vertion of the first picture. I have to have the measurement that goes between the top of strut towers . And from the strut towers to the front of the chassis. thanks guys. I new fellow birds would help!!!!
HI T
"I have to have the measurement that goes between the top of strut towers . And from the strut towers to the front of the chassis." I think it is called a jig with brackets!! regards mike
Autodidactic user
I think that the Body Repair manual has these measurements in it. I'll post them tonight when I get home from work.
HI David, is this section the one you where thinking of,
![]() ![]() ![]() ![]() (posted here for educational purposes only) to clarify the question asked Is the car a repair job or panel replacement due to tin worm? regards mike
Autodidactic user
Very similar to what I remember. I have a Porsche Service School booklet called "Economical Body Repairs" with these measurements (I think). If they are different than MBs, I'll post when I get home.
That exactly what i need!! is there more to those pictures? if so please send
If there is another service booklet It would be great if i can get a scan Thanks to all TD |
could i please get a copy of your "Economical Body Repairs" booklet |
Slumlord
Was that from me? And the CD didn't work???
Autodidactic user
TD,
My stuff appears to be the same as MB's. Here is a scan of the body dimensions from Chapter 8 of the Factory Workshop Manual, Volume VI. The diagram is 11" x 17" so the scan is the best I could do! ![]() © Dr. Ing. h.c. F. Porsche A.G. (posted here for educational purposes only). The Economical Body Repairs manual is 72 pages long and I only have a flat bed (1 page) scanner so it will take forever to scan the entire book in. My scanner takes a couple of minutes per page. I guess I need to move into a more modern age! Anyway, I found this manual on Ebay in a supplement to the Workshop Manuals called "Body Repair." My copy is dated August 1979 and has four sections, welding, repair benches, body jigs and publications. The publications section includes three service school manuals called "Economical Body Repairs," "Welding Galvanized Sheet Metal," and "928 Repair Jobs on Aluminum Body Parts." The only diagrams in the Economical Body Repairs manual that look like they may be useful to you are the ones already posted here. At any rate, here are the covers of the Economical Body Repairs and Welding Galvanized Sheet Metal service manuals in case you find them for sale anywhere: ![]()
abides.
A factory service manual with the title "Economical Body Repairs?" I can only assume that something was lost in translation...
you guys are great
PBH tes it was you the CD was broken in shipping PLEASE resend
TD |
HI gtc
"A factory service manual with the title "Economical Body Repairs?" I can only assume that something was lost in translation.." this is for the German insurance as thay alow 1/2 panels to be fitted and 1/2 chassis legs , also the car can be worked on with the minimal dismantling to make the repair "Economical" ![]() 1/2 panel's to be fitted ![]() (posted here for educational purposes only). regards mike
