Originally Posted by pete-stevers View Post
, but what would i do to recurve a dizzy.....
find a pro engine builder around here that knows about your engine.
In my original CIS 2.7 & dizzy i knew that the advance was adjusted to meet smog regs with the vacuum canister. I disconnected the hose permanently and only used mechanical advance. I set total to 35 deg. Not only did it run better but it also ran a bit cooler.
I have no experience w/3.0, but i just might try running mechanical if it was mine till i had further curve info.
I would guess track pelicanheads might know but I've never seen the issue mentioned one way or another. I've asked about 2.7 & 3.0 recurved info but never received an answer. When i installed carbs i knew i had to do something so i installed a 2.7 RS dizzy that has a steeper low rpm curve and a high initial of 10deg advance. Even carb guys that had their carbed engine's dizzy recurved never replied to my asking what their curve was.
it's one of those black holes around here.
good luck
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-04-2007, 12:00 PM
19 years and 17k posts...
azasadny's Avatar
Carbs (Webers or PMO's)!!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 09-04-2007, 12:11 PM
Evil Genius
Rusty Heap's Avatar
See my sig line for my mods.........pulls much harder and revs faster 3,000 up to 7,000 rpm.
Life is a big ocean to swim in.
Wag more, bark less.
Old 09-04-2007, 12:23 PM
Carl Bauer's Avatar
Check the throttle linkage on top of the engine. You may not be getting full throttle either because the bushing is worn out or because the linkage isn't adjusted correctly.
Carl Bauer - 1979 RoW 911SC - Orange Bar Products
Old 09-04-2007, 03:31 PM
10zz964's Avatar
great read here.
http://www.pelicanparts.com/techarticles/911_engine_rebuild/911_engine_rebuild2.htm
Old 09-04-2007, 10:43 PM
jwetering's Avatar
+1...before all the other suggestions are implemented. Fast throttle response feels like hp.
jasper
2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car.
past: another 2002 996 and a 1978 SC with-webers-cams-etc.
Old 09-04-2007, 11:39 PM
