		 find a pro engine builder around here that knows about your engine. In my original CIS 2.7 & dizzy i knew that the advance was adjusted to meet smog regs with the vacuum canister. I disconnected the hose permanently and only used mechanical advance. I set total to 35 deg. Not only did it run better but it also ran a bit cooler. I have no experience w/3.0, but i just might try running mechanical if it was mine till i had further curve info. I would guess track pelicanheads might know but I've never seen the issue mentioned one way or another. I've asked about 2.7 & 3.0 recurved info but never received an answer. When i installed carbs i knew i had to do something so i installed a 2.7 RS dizzy that has a steeper low rpm curve and a high initial of 10deg advance. Even carb guys that had their carbed engine's dizzy recurved never replied to my asking what their curve was. it's one of those black holes around here. good luck
	Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6  |
			 19 years and 17k posts...
			Carbs (Webers or PMO's)!!
	Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com  |
			 Evil Genius
			See my sig line for my mods.........pulls much harder and revs faster 3,000 up to 7,000 rpm.
	Life is a big ocean to swim in. Wag more, bark less.
			Check the throttle linkage on top of the engine.  You may not be getting full throttle either because the bushing is worn out or because the linkage isn't adjusted correctly.
+1...before all the other suggestions are implemented.  Fast throttle response feels like hp.
	jasper 2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car. past: another 2002 996 and a 1978 SC with-webers-cams-etc.  |
