Howard 2003 996tt 1997 911 Coupe Artic Silver (sold) 1988 Black 911 Coupe (gone but not forgetten) Last edited by plymouthcolt; 09-12-2007 at 04:06 PM.. |
(Last compression test was about 2 years ago and it was 155 across the board) Thank you everyone for your help. Hopefully it is not the valves and I get many more miles out of the girl without having to rebuild.
Howard 2003 996tt 1997 911 Coupe Artic Silver (sold) 1988 Black 911 Coupe (gone but not forgetten) |
I am going to replace my wires with these from http://kingsborne.com/wire.htm. 7mm copper 19 strand.
I am going to request Kingsborne crimp on the M3 threaded sleeve on loose wire which I will cut to size, and I will handle the distributor ends. My question is should order new distributor and coil connectors? Pricing on the net is around $7.99 for the distributor and coil connectors, or should I transfer my current ones and put them on the new wire? I am going to reuse my Beru connectors as all but one tested at specs.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Thread Tools | |
Rate This Thread | |
