Idle change warm to hot at stop, which device am I looking for? 82sc
WHile its not a big problem I just want to know if its normal or is something out. I set the idle mix and have a solid idle (maybe a tad low but strong and solid) when cold and warm.
After long drives or when its excessively hot (meaning normally the temp gauge is way below the middle but during a 95+ day it will creep up to the middle or so) I notice the idle change at stop lights or when sitting still.
Its not a creep and hold like a leak but a ramp up a few rpms then kick back down as if something is opening and then closing.
What components should I check or replace or is this just a normal device richening or leaning the idle at the stop?
Thanks for any help
D.Brisson
82sc GHL single in out, cat bypass. Otherwise stock with new filter, plugs rotor and cap.
Sold my MG so now its into really tinkering with this one....
Old 09-03-2007, 06:01 PM
Band.
What year of car?
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 09-03-2007, 06:02 PM
SCWDP911's Avatar
Originally Posted by Gogar View Post
What year of car?
"82sc GHL single in out, cat bypass. Otherwise stock with new filter, plugs rotor and cap."
Shane
- 1984 928S
Old 09-03-2007, 06:23 PM
The lower part wasnt there during the first reply added during edit, although the 82 was in the title. Any way where should I start? I am guessing the "check the pressures and cis overview. ...
Old 09-03-2007, 06:49 PM
Designer King
Paulporsche's Avatar
Your warm control pressure might be a little low, resulting in a too rich warm condition. It's also possible your mixture may be simply set a little rich.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 09-04-2007, 06:23 AM
