Questions about first Dyno run
I'm heading for my first ever Dyno run this Friday and was curious what (if anything) I should be prepared for.
I've put on about 1500 miles since I completed the total top and bottom rebuild and I thought I would do a Dyno run to see what kind of HP I'm getting. The car is an 87 3.2 I left pretty much stock except for the GHL muffler, cat bypass, and Steve Wong chip. I thought about bring the stock chip to compare? I'm sure the guys at the Dyno shop will be able to interpret the results for me but I'm trying to get up to speed on what things Porsche (87 Motronic) specific I need to know and if there's anything I may need to adjust and run again? I've searched a bit on PP but came up empty, if anyone has advice or links that could help get me up to speed I would appreciate it. Thanks Brian
1987 911 Coupe-Current ride 2007 997TT-Sold 2006 997 C2S-Sold 1991 964 Turbo-Sold 1987 911 Targa-You never forget your first |
ps: I did my runs in 4th gear, WOT from around 40 mph up to 110 mph (or so, ...where the dyno shut down). Much of Steve's tuning are in the mappings for partial throttle, so it's certainly not an exact science at all in attempting to 'quantify' these things...or maybe Loren's right after all
MBruns for President
Relax - the dyno guys are experts and see many cars coming through - They will typically be the ones that "drive" your car during the dyno.
If it's a dynojet 248 have them save the files on your computer drive (zip drives work great for this) send to Steve W to see if he can do any more tweeking. here's a link to my dyno experience (and commentary) Oh Dyno we will go...
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Can Steve do any additional tweaking without accompanying a/f numbers? Not questioning, just mentioning (for Brian), and curious...
Good information, thanks guys. I'll post the numbers next week.
the dynojet will include AF numbers and at specific rpms
You'd really need the AFR numbers in order to tweak a custom chip to your motor - like tuning a musical instrument, you need tools to tune. Otherwise, with an standard chip, you can only map the chips based on the average of collected samplings. Over time as more samplings are performed, the more tweaked the program gets to match the collected numerical average of a particular engine configuration to maximize power output. As a chip customer, short of a custom remap, you are welcome to free updates to the latest version, so feel free to contact me if you'd like to update your chip to the latest. |
Thanks! I think I will very soon. There's not a thing wrong with the one I've been running for several years, but I'm sure you've refined it a bit more since then.
AirBorne!
For what it's worth, I have a SW chip in my car, love it. And I haven't even dyno'd the thing and sent the graphs to SW to tinker. One day I'll get around to it.
Love the Chip SW. Wellborn
2008 997 C4S Silver, Kitty Cat, 1989 3.4 911 Silver Carrera, Erica, 1989 944S2 NASA GTS2, Iris, 1988 944 DE Car, Backdate 1975S to 1970s w 3.0 PMO - Roxanne, 1967 911 normal w 2.2s engine w S goodies, 89 VW Cabriolet - 2.0 conversion - sold and missed |
Here's the shops website and info on thier Dyno
http://www.idc-solutions.net/ChassisDynoTuning.html Looks like I'll be getting the A/F numbers Steve mentioned
Here's the numbers, little lower than I had hoped and it seems the graph is a bit choppy. Any thoughts or comments?
Your HP number is probably about right, but I'd say your torque is low. It does indeed look choppy and a bit rich.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Here are the A/F numbers. I really know nothing about analyzing these numbers so I'm looking for advise.
The guys running the Dyno seemed to thi9ng it was running rich on the low end and lean on the top end?
Are you sure your O2 sensor is working/connected? Is the TPS switch tripped too early? The DME goes closed-loop (and starts ignoring the O2 sensor), on full throttle - then it only uses the fuel map entries. Looks like it goes closed-loop too early and that the fuel map is rich, to me. Which makes no sense at all, unless it's a custom chip for a very different motor... Maybe you have a bad injector dumping too much fuel once the duty cycle gets up there? Luckily, Steve W is on the thread, so someone who knows what they're talking about will be along soon, I'm sure.
'77 S with '78 930 power and a few other things. |
You are definitely too rich above 4200 rpm and too lean below 4000 rpm. This will be robbing you of power especially at higher rpm's. The lumpiness looks odd for a stock motor. You really should do a run with your stock chip and get an idea if all of your components are working correctly. If they are, then you will probably need extensive remapping of your new chip.
Steve Sapere aude 1983 3.4L 911SC turbo. Sold |
From the AFR curve, it looks like a dyno run where the WOT switch is not activating. Did you check it previously? Also, do you know how rpm was measured? Peak hp at 6500 doesn't look right. With some dynos such as a Mustang, the operator revs the motor to 4000 rpm, eyeballs the dash tach, and enters that as the rpm calibration - not exactly accurate. I wouldn't be so concerned about the absolute numbers, as different brands of dynos output different numbers. There aren't many people who use DYNOmite dynos, and I think I've only seen one or two dyno runs from that type of dyno, so there's no basis for comparison.
You won't have to do a thing other than have the car warm. They'll tell you to stand back--way back.
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
Doesn't want/need a 3.6L
This is what you want your a/f ratio to look like when you are done dyno tuning. One run is the motor as a 3.2L with "off the shelf" SW chip, Dansk premuffler and Dansk final muffler (similar mods as to what you have) and the second is the motor as a 3.5L twin-plug with more bells & whistles:
![]() Steve will get you there as long as you provide him the data to work with. ![]() Ralph Last edited by Carrera3.5L; 09-08-2007 at 10:53 AM.. |
