Leaving car in gear while parked?
Been having a debate...
Does doing this cause undue damage or stress to components?
1987 535is, 1966 GTV, 2015 F-Type R, 2013 991 C2, 2011 E550c, 2007 997 C2S, 1987 911, 1958 356 1600s, 1956 356 1600s |
Don't know about that. But, when I park, I always park clutch in, e-brake on, then brake off so the car is "against" the E-brake. Only after it settles do I let my foot off the clutch.
'85 911. White - 53,000 miles bought 3-16-07. "Casper" '88 924S. Blue - 120k miles bought with 105k miles. '94 968 Coupe - White - 108,000 miles bought 9-28-17 '09 Cayman - Grey - bought 9-8-20 |
Gearbox internals can be damaged and at a minimum, stressed, if the car's in gear. Otherwise, no problem. I place it in gear as a secondary measure when parked on a hill. Parking brake with the front tire banked against the curb are primary means of keeping it at 0 mph.
Sherwood |
I do like Wolfe does...imo, a parked car left in neutral is not safe. Out of habit (been doing it for 30 some years), I always leave her in reverse too.
Sherwood, I assume you mean gearbox internals can be damaged if, say, somebody backs into while unparking or whatever? Certainly there can't be any damage from leaving a car in gear with the parking brake on if there's no external stress. And I'm assuming that nobody's dumb enough to depend 100 percent on parking in gear--i.e. no parking-brake use.
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
I only do it on steep hills, and always ebrake first... I just never do it out of practice after racing/DEs etc...
-Andy '67 912, '92 C2, and '93 RSA - all gone
Dog-faced pony soldier
Yep. Same here - all my cars are manual transmissions and I always pull the e-brake first (before letting off the regular brake), then shut the car off in neutral, put it in gear and then release the clutch (with the engine off and the wheels being held by the e-brake). It's a second level of protection - a tertiary one if on a hill (I cut the wheels into or away from the curb if I'm facing down or up a hill respectively).
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
Ditto with all those who leave it in gear after secured by e-brake. Never had a problem in over 45 years with the trans, but then the car was never bumped hard by an idiot while parked--my only fear.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
I almost painted my 912 Ossi Blue... stuck with Tangerine. If they bumped my car hard enough to hurt the gearbox, they better hope they hurt the gearbox so I can't kill them for the dents or scratches they put in my bumper
Not near the stress as the 'stomp and steer' to redline...
83 911SC 70 911T |
I left out that part of my answer that should have included damage caused by an outside force bumping into the vehicle. As for putting the gearbox in reverse, that's the gear with the most gear reduction, so it's more difficult for the car to move. However, if hit from behind and the car moves forward, the engine rotates opposite the normal direction of rotation. That could conceivably stress the valve train components as well as the aforementioned gearbox internals. Sherwood |
To be totally safe, don't ever park it, or leave it in neutral and use one of those "boot" things...or just keep doing what you're doing and not worry about it.
'84 911, some sort of red color '05 Subaru WRX wagon |
rotating the engine in reverse can pop the cam chain off the intermediate shaft sproket.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
BOTH FEET IN!!!!
Whenever I park mine in the garage, I always have the parking brake ON, and the transmission in NEUTRAL. My parking brake works great, no more than three clicks when set. I pretty much do the same when out in the public domain, but... If I am parking on the side or a mountain, I will place it in gear, either 1st or reverse, and also set the handbrake, and if there is a curb where I am parking, I will turn the wheels so they will be locked in the position pointing toward the curb. Just my $0.03
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
I use the E-brake only with the car in neutral if I have to park it away from my garage.
When it is in my garage I leave it in neutral with no E-brake. It can not roll out of my garage.
Michael 83 SC Coupe |
+1 WolfeMacleod.
The E Brake should "hold" the car. Once it holds, then place in gear. Same with automatics. Better than the transmission gears "holding" the weight.
pozee |
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Want to explain how??
Rick 88 Cab |
