RichF's Avatar
what weight and filter should i be using?
what brand, weight, and oil filter should I be using on my 2.4. I used a fram and shell rotella T last time but im having a hard time finding the rotella T agin.
"Work harder........... Millions on welfare depend on you"
" If you aint cheaten you aint tryin"
Old 09-09-2007, 06:53 PM
Castrol GTX 20W50 with a Mahle OC-54 oil filter (order from Pelican) is a good combination. The internal construction of Fram filters make them a poor choice for the 911 oiling system.
Old 09-09-2007, 08:33 PM
Regis turd ab user
http://www.lnengineering.com/oil.html
Read on !!!! It's good for you to know, and determine based on your driving style, climate, and cars condition.
Old 09-09-2007, 08:35 PM
AutoBahned
RWebb's Avatar
avoid Castrol - find Steve W's posts and read them.
Old 09-09-2007, 11:00 PM
burgermeister's Avatar
+1 Mahle filter.
AutoZone sells Rotella T (at least around here...but everyone in Michigan drives a truck, and quite a few are diesels).
I currently have Valvoline 20W50 racing oil in mine, largely because the local parts store had a case sitting around. IMHO, if the engine is so picky that using the wrong brand of oil screws it up (once it's broken in), then I'll just junk mine when she blows and forget all about Porsche cars for the rest of my life. I personally do not have time or energy to obsess about oil brands...
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 09-10-2007, 02:51 AM
rnln's Avatar
RWebb, basically, what is it about?
Fat butt 911, 1987
Old 09-10-2007, 01:06 PM
AutoBahned
RWebb's Avatar
what?
the Castrol? (puts yellow-brown deposits on motor internals)
or the Zinc? (conc.'s of ZN reduced recently & that lowers effective anti-wear protection even in oils we thought were good)
or synthetic (proven to protect better than dino oils in your motor, while needed less of the additives that can gunk up the motor)
Old 09-10-2007, 02:33 PM
