the head ports look just like Johns(disfin) did. Looks like a used crack pipe, I imagine.
Sorry for the pessimism Dave. Obviously I don't have the details, but with those leak down numbers and the amount of oil that's making it's way into the combustion chambers it's my guess. Maybe it's all valves and guides. Maybe you'll get lucky, I never do. I'll be curious to hear how the pistons and cylinders measure.
[QUOTE=charleskieffner;3473161]
powder coat engine tin/fan/etc. it goes on and on............. cad plate fan housing strap cad plate all nuts bolts washers (cheap) QUOTE] Not to hijack this link, but I thought a top end was around 5k? Patrick quoted me that price when my 3.0 eat a piston ring? Chuck do you know of a shop that does this in Az? I am thinking of doing and engine drop to clean the engine up and fix leaks |
It's now under the "Thread Tools" at the top... took me awhile to find it too. Too early for the P & C debate until they are measured. 400mile/qt is alot of oil - better to do this now than to wait until you drop a valve... |
Can't always count on what the eye sees in the exhaust ports as far as buildup goes. If someone runs some Berryman B-12 or Techron in there, those big globs would be gone and you'd think everything was decent- except the port showing oily film/wet versus big glob of crud. Hence the reason oil consumption is a good gauge to go by.
My car had 78K on the clock and both the intakes and exhausts were goners, along with heavy wear on the rockers and shafts. Oil consumption was high and so was the valve clatter. No sign of oil staining in mine like oil changes may have been too infrequent or low quality oil usage. |
[QUOTE=KTL;3491253]Can't always count on what the eye sees in the exhaust ports as far as buildup goes. If someone runs some Berryman B-12 or Techron in there, those big globs would be gone and you'd think everything was decent- except the port showing oily film/wet versus big glob of crud. Hence the reason oil consumption is a good gauge to go by.
QUOTE] At least two of them were wet and oily. |
Dave,
Like donnie mentioned, your exhaust ports look like mine did. Here is a before and after picture. The head work was done by Bob at Anchor Atlantic in NJ. Based on your smoke on decelleration, you will correct the majority of your oil consumption by doing the head work alone. Rings are a good idea too. Remember, sloppy valve guides will create oil consumption issues, but not the compression/leak down issues you are having. My p&c's measured in spec and i hope yours will too. Good luck, and keep the pictures coming! John http://forums.pelicanparts.com/uploa...1190494327.jpg http://forums.pelicanparts.com/uploa...1190494345.jpg |
cams, cams, cams, cams. Get a 964 grind on your cams. Time for new valves. Expnsive I know, but at least do the exhaust. I hope he is going to pull the pistons and mic the lans. If OK reuse your cylinders and rings. Have the pistons bead blasted. Heads too. It is only money but you will be happier in the end.
So Dave,
how did the top end rebuild turn-out and what was the final cost? |
nice thread. not to hijack, but what is wrong with castrol oil? i just changed my oil on a mew to me 89 911 and i used castrol 20/50.
thanks |
super duper dave keeps us posted.
fender guy the two i know are patricks and jack at stuttgart. take your pick. or my buddy nels if hes not building vintage bug vans or off road porsche motors. |
I know it is long but well worth it. |
well its been a long time - waaayyyy too long. She should be on the road tomorrow. This is what she looks like today. Sorry about the pic quality - all i had was my phone.
http://forums.pelicanparts.com/uploa...1193676619.jpg |
Purty!
You got lucky on the Ps and Cs? I take it they were in spec.?
| All times are GMT -8. The time now is 03:47 AM. |
