If you need a sealant for tapered threads (pipe threads), use PST; made by Loctite. It contains teflon, but is not a solid like tape that can block an oil passage. Recommended by Carroll Smith (Design to Win, etc.).
Sherwood
http://members.rennlist.org/911pcars
Old 09-13-2007, 11:28 AM
eR1c's Avatar
how man quarts do we typically need for a transmission change? I believe I have the 915 transmission, ('77 930).
I was going to order the swepco trans oil from PP's and do the change on the next rainy weekend (when It's too crappy out to go driving).
1977 930 Turbo
Old 10-08-2007, 03:33 PM
Purchase the gallon. You'll have some left over to store for the next XX years.
Sherwood
Old 10-08-2007, 04:58 PM
ianc's Avatar
TERRIBLE IDEA. Not more than a week ago, Jim Sims posted on the danger of this -- it allows small bits of plastic to get into and clog the tiny oil passaes in the motor.
How on earth are you going to get bits of teflon tape in the motor from putting it on the trans fill\drain plugs?
Not that it's a good idea mind you...
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 10-08-2007, 06:22 PM
burgermeister's Avatar
ianc
It could be carried by an African Swallow. It could grab it by the husk. As the motor and tranny share the same compartment, the non-migratory nature of the African Swallow is not an issue in this case....
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 10-09-2007, 03:01 AM
AutoBahned
RWebb's Avatar
cute - and I apologize for the typo
- the principle still stands however -- there is no need to use teflon tape and you are liable to get it inside the unit you are working on, with varying degrees of trouble being caused.
Old 10-09-2007, 02:21 PM
Noel's Avatar
I prefer to lift the entire front of the car using the beam behind the AC condensor and the fuel tank. Use a large piece of wood between the chasis and the jack. Place jack stands under the rear torsion bar caps prior to jacking up the front, then lift the rear using a piece of wood under the engine and reindex the jack stands. Been doing it this way for many many years.
Gone but not forgotten -
1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C
Old 10-09-2007, 02:23 PM
