RETIRED
Joe Bob's Avatar
Anybody ever check their speedo via GPS?
Just did mine....I expected it to read high....boy was I surprised when it found I'm 10% LOW.
I'm running 245/45/16s on my SC and that's a bit shorter than stock. I'm actually doing 77 while seeing an indicated 70.
Up to 30 mph is nuts on....after that........
On my 356 replica I have an adjustable electronic VDO. Fun having NEW and accurate gauges.
2012 ML350 3.0 Turbo Diesel
Old 09-12-2007, 05:04 AM
Friend of Warren
I have a handheld Garmin Etrex. Checked the speedos in all my cars with it. My Bugeye Sprite speedo didn't work so I just used the gps for a speedo.
My '86 was 10% confident. I had it recalibrated by North Hollywood Speedometer when they reworked my speedo and tach a few years back. Now it is 100% accurate at all speeds.
Kurt V
Old 09-12-2007, 05:31 AM
While I never checked my 911 I have checked my MB SL, '02 Explorer and '99 CRV. All speedos report a higher-than-GPS speed by between 5% & 10%.
Used a Garmin StreetPilot.
Warren & Ron, may you rest in Peace.
Old 09-12-2007, 05:36 AM
I always thought my speedo read high by at least 5 mph. So, if I'm reading 80 mph, I should actually be doing 75. Jeepers, now I may be doing 85. Must check...
87 blk coupe
Old 09-12-2007, 05:38 AM
If this is typical, (showing higher speeds than normal) then is my odometer possibly showing 10% higher milage? That would be significant and is it possible/legal to correct back?
Tony G
2000 Boxster S
Old 09-12-2007, 09:35 AM
It's NEVER legal to turn back your odometer.
I checked my 1973. GPS says 65 and speedometer says 70.
I'm running 195/65/15's which should read lower than stock 185/70/15's but it doesn't. I've just learned to subtract 5 MPH from the speedo.
Old 09-12-2007, 09:46 AM
msucro's Avatar
Send a message via AIM to msucro Send a message via Yahoo to msucro
I checked my gf's 2001 Boxster S... read about 4 mph high anywhere from 50-85.
Marcus
Old 09-12-2007, 09:53 AM
madmmac's Avatar
Gps checked on my 911 with standard tires/wheels is exactly 5mph slower than the speedometer reading at all speeds.
4runner is right on at all speeds.
madmmac AKA Mitch
1984 Factory Turbo Look
2006 4Runner
1998 TRD Supercharged 4Runner (Sleeper)
Old 09-12-2007, 09:54 AM
Ok, thx. 5 mph slower than reading. I think that's the norm for at least 84 through 89 Carreras.
87 blk coupe
Old 09-12-2007, 11:21 AM
I checked my my SC with a GPS and, running 245/45-16 tires, the spedometer runs 5-7 miles high depending on speed. Seems to get a little more accurate at higher speeds (like over 55) and a little less accurate at lower speeds.
1979 911 SC Silver
2002 996 race car
2005 Ford Excursion
Old 09-12-2007, 11:31 AM
Fuchs w h o r e
What do you think the accuracy of your GPS is?
Old 09-12-2007, 03:18 PM
SCWDP911's Avatar
Mine runs slower than indicated - about 5 mph all the up the dial once past 25. Checked with a Garmin. Stock tire sizes...
Shane
- 1984 928S
Old 09-12-2007, 03:27 PM
Grand Am/IMSA Data Guy
Porsche84's Avatar
My 2002 Jeep Grand Cherokee speedo reads 1 mph high at 70mph), my 86 Chevy truck is dead nuts (at 65 mph), my wife's 328i BMW is about 2 mph high at 70. I have not checked my Porsche because it is only driven on the track
Jerry Austin
AIM Data Products Dealer
84 911 3.6 track car - Sold
Morris Minor Van with S2000 running gear
http://austinmotorsportsllc.com/
Old 09-12-2007, 03:50 PM
I've checked the hand held GPS that I used to check the Porsche against another expensive street address finder GPS I have and, both read MPH the same.
On a stretch of road between here and Sonoma, I checked the street address finder GPS unit against mile marker signs at 60 miles per hour and it took 1 minute so I know that unit was correct and as such, the other should also be correct.
Old 09-12-2007, 04:01 PM
ausgezeichnet's Avatar
I've noticed a delay in my GPS altitude readings as I am driving a highway speeds. It probably is the same for speed so keep your speed steady when measuring.
Mike
'84 911 Carrera Coupe (totaled)
'83 911 SC Coupe
‘06 Aston Martin Vantage V8
Old 09-12-2007, 04:06 PM
Ova Day
msterling's Avatar
GPS unit altitude readings are relatively inaccurate. Within 100 feet is unlikey with mine. It actually uses barometric pressure to "guess". The speed readings are updated much more quickly and precisely using GPS signals. Still, an average over a period of time is a better indicator.
88 Triple Black 911 Carrera Cab, ex Garage Queen
05 BMW E46 M3
21 Tesla Model 3 LR
08 BMW 328xi
15 Ford F150
Old 09-12-2007, 05:08 PM
Detached Member
Hugh R's Avatar
NH Speedo told me all the 84 to 89 speedos from porsche are off by 5-7 mph at speed. The speedo does not dictate odometer readings.
Hugh
Old 09-12-2007, 05:14 PM
Hugh,
Over or under? My 88 (89 model year, 16 inch std wheels) speedo shows 107 kmh when travelling at 100 KMH
Regards
Bruce
Past 89 3.2 Carrera (Sold), 94 3.6 Turbo (Sold)
Present 94 C36 AMG M-Benz, 93 SL500 M-Benz, 08 C63 AMG M-Benz
Old 09-12-2007, 07:40 PM
According to Garmin (with WAAS) 0.11mph accuracy.
Previous technology is not as accurate.
Old 09-12-2007, 08:10 PM
Won Won is offline
Won's Avatar
It was discussed before and apparently the speedo reading and odometer reading are independent of each other. Someone here tested them with mile markers - at 60 mph, in 1 minute, one would have driven slightly less than 1 mile, according to both the markers and the odometer.
83 911SC Targa
Everything I say is my personal opinion, and has nothing to do with my team.
Old 09-12-2007, 08:56 PM
