Somatic Negative Optimist
Glad it worked.
Four years at the Polytechnicum Zurich, CH paid off. ![]() I still recommend Moly for lube, it stays longer.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Habitual User
Well, after reading the Seine Gate Shift web page I became concerned about the new spring pressure on the 1-2 plane causing some wear in the trans. I don't recall it being there before but i have a little noise in 1 & 2 now that disapears as soon as i move the shift lever slightly to the Left from its sprung position. There is no way I'm taking off that spring so I decided to make a plate with tabs like on the 5-R plane to relieve the pressure.
This is the finished plate next to a standard plate I borrowed from my mechanic to use as a template. I used 1/16 303 stainless steel.Could have used 3/32. Also in the picture is the shift lever tab I made, before the final bend.I needed to install the plate to measure where to bend the lever tab. ![]() The shifter with spring only. ![]() Plate installed, lever tab held in place for measurement of last bend. ![]() Sorry but I made the bend and installed the lever tab with another hose clamp without taking another picture. It all works perfectly. The new tab holds the lever just slightly off its free sprung position. Don
![]() '80 911 Targa |
You're puttin' the fab back in fabulous there buddy!
I was impressed by Won's elastic band solution. You've taken it to another level. Bra-freakin-vo.
jasper 2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car. past: another 2002 996 and a 1978 SC with-webers-cams-etc. |
If it works go with it. Slap a boot over it and know one will know about the hose clamp and spring. If it breaks it cost's a few cents and won't leave you stranded.
Good fabbing!
Jeff Hail "All men dream: but not equally. Those who dream by night in the dusty recesses of their minds, wake in the day to find that it is vanity; but the dreamers of the day are dangerous men, for they act their dream with open eyes, to make it possible" |
Blew--you lost me. What's the purpose of your new plate and "L" shaped tab? I also installed a spring like yours.
Mike '86 911 coupe '85 BMW 535i '11 Cayenne |
Predictably, the rubber bands where shredded to pieces not long after the "installation". I've bought an actual spring to do what Gunter suggested, but a day later I blew a CV joint and my car's been in a million pieces since then.
Good job Don, I thought about making the tabs a la Seine Shifter but cutting the shape out of a plate couldn't have been fun with what tools I have so it never happened. What did you use to cut the plate? Mike, take a look here: http://www.seinesystems.com/GateShift-1.htm The new tabs relieve the spring tension in 1-2 plane just like the tabs on 5-R plane does. Jasper, thanks! I had a chance to co-drive your old beast with Denny at an autocross the other day. Man, that's one hell of a car. I'm going extra slow with the work on my car in hopes that Denny might let me drive it for another session
83 911SC Targa Everything I say is my personal opinion, and has nothing to do with my team. |
Habitual User
Thanks, it took about an hour. I've access to the machine shop at work. Band saw and conventional mill.
Mike, It could be confusing because there is no picture of the final bend in the "L" shaped bracket.Sorry. Don
![]() '80 911 Targa Last edited by BLEW911; 06-07-2008 at 10:37 PM.. |
![]() ![]() Another way for the same result......We all do that in France for more agreement. A bit more expensive than the first solution proposed.....one euro..... Last edited by cdrik915; 01-04-2008 at 08:28 AM.. |
I precise that it's recommanded to change the shift rod bushing , it's not expensive and change the feeling of this old 915.
Adding to this solution , that's become more pleasant. |
DPHANS
Next to do. Change position of the gear shifter. (very simple to do)
J'aim cette solution ![]() Qu'est-ce que sais “Spring” en francais?
Habitual User
Ok, here is a picture of the shift lever tab after the final bend. Sorry, still no pic of the final instalation.
Still here
I may have missed it in these posts, but there is a reason kits such as seine have a second set of tabs for the 1/2 plane. without them when in 1st or 2nd those bands are putting tension on the shifter and unwanted pressure on the transmission internals. I know most dont spend a lot of time in only 1/2, so may not be a big issue.
Bob Cox 78 930 clone project car. 87 924S resurrect at some point. 84 928S, Ruby Red linen/brown interior - sold ![]() 86 944 turbo my new DE/track car - sold
hmm yep, missed the whole second page.
