Somatic Negative Optimist
Gunter's Avatar
993 basic vs. 993"S" question.
What constitutes an "S"?
What extras come with an S?
Thanks.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 09-12-2007, 08:23 AM
Bye, Bye.
Scooter's Avatar
Depends on if it is a C4S or a C2S. A C4S will basically be a turbo without the turbo, which means a beefed up suspension and larger brakes. Both will be a widebody, which means larger fenders in the back, wider wheels in the back and a different front bumper. Other than that the engine is the same and options are the same.
Elvis has left the building.
Old 09-12-2007, 08:35 AM
The 993 "S" is a wide-bodied variant.
They made two versions; the C2S and the AWD C4S.
C4S's received the AWD system, the Big Red brakes on the TT and solid-spoke versions of the TT's hollow-spoke wheels.
C2S's had standard 993 brakes and the same wheels as above.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-12-2007, 08:45 AM
Bill Verburg's Avatar
true
Not true. there are only 2 suspension pieces that are different on the turbo, the scizzor pieces in the back, and the S uses the same as all other n/b 993. The wheels are not wider, the same 8&10" width x18 wheels are used w/ spacers in the back
the biggest difference between a 2S and 4S besides AWD is the brakes. 4S has the tt big reds and electro- hydraulic booster. 2S has vacuum boosted like the regular 993n/b
Bill Verburg
Old 09-12-2007, 08:47 AM
Bye, Bye.
Scooter's Avatar
Bill, I believe my statement is at least partially true.
It is also my understanding that the C4S also received the beefed up sway bars from the turbo. Is that correct? The sways are what I was mostly talking about when I said "beefed up suspension." I was correct on the brake upgrade. I guess I stand corrected on the wheels, although I don't understand how I am wrong, because I see turbo twist 11's all the time, which do not fit a NB car. Bill is the wheel man, so I believe what he says.
Old 09-12-2007, 09:07 AM
GrantG's Avatar
On normally aspirated 993's, "S" means it's more "Spensive" but not any faster
2022 GT3 Manual, 73 Carrera RS 2.9 Twin-Plug MFI Carbon Fiber Replica
Former: 18 GT3 Manual,16 Cayman GT4, 73 911S, Two 951S's, 996 C2, 993 C2, BMW 635CSi Euro, Ferrari 550 Maranello, 06 Evo IX w/ many mods
Old 09-12-2007, 09:51 AM
athe turbo uses M030 suspension, same as what an M030 n/b uses.
In US the ride heights are all the same, RoW regular is lower and M030 is eevn lower
the only turbo specific parts are the 2 lateral scissor pieces.
11s came out later on 996tt and GT3
Bill Verburg
Old 09-12-2007, 11:15 AM
Bye, Bye.
Scooter's Avatar
Thanks Bill. What you said makes sense.
Old 09-12-2007, 11:26 AM
Mark Wilson
Guest
Posts: n/a
An S gets you a bigger butt and bragging rights that you have a somewhat rare car. I would take either but am happy that Ginger is a fat bottomed girl.
Old 09-12-2007, 12:32 PM
MIK911's Avatar
You guys left out the most important difference:
The C2S has the ULTRA COOL split grill:
Mike
'86 911 coupe
'85 BMW 535i
'11 Cayenne
Old 09-12-2007, 11:13 PM
Max2.0's Avatar
About $15K in resale dollars!!!
IF it is a C2S...
C4S? Not so sure... Not many fans of the truck like AWD system...
1983 911SC... Concours Garage Queen
1987 Carrera M491 Cab... Movin' on out...
1992 968 Coupe Track Car... Gone
1968 911L, '73.5 911T, '75 911S SA, '77 911S Targa, and so forth, thru a '90 S2 Cab...
Old 09-13-2007, 06:42 AM
Light,Nimble,Uncivilized
Ginger is a whore.
I do like the split grill above though.
Mark, I see only one car in your sigy. What happened to the early ride?
Drago
'69 Coupe
R #464
Old 09-13-2007, 06:52 AM
Mark Wilson
Guest
Posts: n/a
IF it is a C2S...
You obviously don't have a clue what you're talking about - on either count.
Old 09-13-2007, 07:22 PM
Mark Wilson
Guest
Posts: n/a
Originally Posted by Drago View Post
Ginger is a whore.
Yo Drago - Boo Boo is going back to PO. He's going to finish her up. How's the smurf?
Old 09-13-2007, 07:25 PM
C4S is far from a truck. You can't even tell its got the 4wd until you go an pull a stuck pickup out of the mud or pull a stump.
Old 09-13-2007, 08:22 PM
Mammalian
96740's Avatar
Does anyone have a good depiction on how much wider the S looks from the regular Carrera? A nice side by side.
2007 Cayman
Old 09-13-2007, 08:43 PM
Bye, Bye.
Scooter's Avatar
I've seen the side by side pics many times. Just do a search.
Separately, there doesn't seem to be much of a difference, but side by side....
Old 09-13-2007, 10:06 PM
The "S" is quite the looker. I guess it is a "Turbo Look" in a 993 version? If they had did something to the engine to give it another 50hp over the stock 993 they would of hit a homerun.
Old 09-14-2007, 05:01 AM
Mammalian
96740's Avatar
Thanks. That one show it good.
2007 Cayman
Old 09-14-2007, 05:48 AM
Max2.0's Avatar
Opinions are like ... well you get the idea...
Everyone is entitled to their opinion...
Even if they can't back it up with substantial evidence!
A variety of '97 "Plain" 993's for sale at $40K, +/-...
Now try to find a NICE (less than 20K miles and all original paint) 1997 993 C2S for less than $55K...
As to the subjective feel of a C2S vs. a C4 or C4S, I have driven both, and yes, I can feel the substantial difference; if you can't, it may simply be that you started with, and are very used to the AWD setup... and that is fine...
Just not for me! But then again I still like the early Longhoods w/o A/C, so go figure!
Old 09-14-2007, 06:25 AM
