Gary R. Last edited by GaryR; 01-04-2014 at 06:24 AM.. |
Functionista
I've yet to open a 911 engine w/o finding a clogged spray bar hole. Which is the main reason why I don't like the oil restrictors as the cam still has a chance to receive lubrication from neighboring holes if there is more oil than needed going to cams.
Also, it should be noted that NASCAR engines keep the entire valve cover full of oil. Not that one should run 911s that way. Just something I found interesting.....
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
Sherwood |
Functionista
Completely full. They also have a check valve that has to be manually released to allow for oil to drain back before vc can be removed. This according to Hot Rod magazine's analysis of NASCAR tech circa 2010. Possibly due to valve springs being the weakest link in these engines.
Reiver
PO may have heard some clattering and had the valves adjusted...the damaged camshafts/lifters never quieted down and rattled and the PO or tech ran the clearances tighter to sell the car to some unsuspecting victim rather than spend the money to repair it. If the engine was pretty silent when you purchased it..those two valves may of been set very tight. (I've seen this before) Like I said..not a quality of lubricant or zinc problem..definitely a poor maintenance problem. If the lubricating oil was to blame..all 12 of the camshaft ramps would show some damage. The reason you wont see this when aftermarket or reground camshafts are installed..the new 911 owner takes care of the car after making the investment in repairs and maintenance. |
Couldn't locate the HR Mag article with that content. This is a HR Mag article I found re: Chevy's R07 NASCAR engine. Chevy Nascar Engine - Nascar's New Chevy - Hot Rod Magazine They do mention bathing the valve springs in lube oil, but no mention of "filling" the entire valve cover as you state. Maybe I'm not reading the pertinent information you are. As you mentioned, NASCAR teams are concerned with valve spring cooling due to continuous high RPM operation (~9K rpm). The R07 engine (as well as Ford and Mopar) has oil squirters built into the each valve cover (possible with a dry sump pump). The large volume of oil draining into into the crankcase requires shielding the cam to reduce further windage loss. I haven't located any information on filling the entire space under the valve cover with oil nor a manual drain back valve to keep oil in the valve cover. Got a link? Valve train movement (mainly rockers) in submerged oil sounds counterproductive for accurate valve timing. oil link to flooding lube for valve springs: 332-428 Ford FE Engine Forum: Latest NASCAR theory on flooding the valve springs Roush Racing's New 822HP Nascar Engine http://www.stevesnovasite.com/forums/archive/index.php/t-198836.html Sherwood |
Very long thread, unsure if this has been posted but- worth a read for those interested...
Engine Oil
Goose- "nothing a year in the tropics wouldn't fix" |
Does any one use brad penn penn-grade 1 sae 30 high performance oil for aircooled engines?
Under the radar
It seems as though many oils have just recently been reformulated. Many oil manufactures now will not post their ZDDP levels!?
I ran across this thread. An SAE engineer states that ZDDP levels are not what matters. He claims to do his own testing. Here is part of the thread. Quote:
OCPO
2018 X5 86 911 Targa 3.2 80 Mercedes 450SL 2006 530xi BillyBoat/H&R's....gone |
PhD on Pending Projects
I am dizzy after all the reading... so at the end of all this... what oil should I be using on my 1981-1991 Porsche 911s???
![]() I am running out of the old stock of boxes of Mobil 1 15-50 (before they changed the formula)... need to start buying and can't figure out what to get...
Drive safe! 1967 - Porsche 912 1981 - Porsche 911 SC 1991 - Porsche 911 C4 Wide-body Cabriolet |
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Has anyone seen or tried Porsche's newly introduced line of motor oils? I recently saw an ad in the recent Excellence Magazine. Seems as if Porsche is looking to expand their "Classic" Line by offering specifically blended oils for two specific engine groups. The red can is a mineral base targeted for the 2.0-2.7 liter engines, and the silver can is a synthetic/synthetic blend for the 3.0 & up engines.
I don't have much info on it, other than what I read in the ad. 'Just curious if anyone has any additional feedback.... Regards, JP NY.
66 Shelby Hertz Renta-Racer 68 Shelby 500KR 78 Ferrrari 308 16 Macan S 11 Speedster |
$13.65 per liter online.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
I'm curious to know who's going to actually step up and purchase ten quarts at that price. After the souvenir hunters have bought their token can - then what?
Kurt |
cycling has-been
still cheaper than the Joe Gibbs that a lot of people have signed on for, based on the recommendations on this thread.
73 911T MFI, 76 912E, 77 Turbo Carrera |
Pre Registered
No its not. Joe Gibbs Driven DT50 15W50 is available at $10.99 a quart . I doesn't come in a pretty can, however. |
