| Registered Join Date: May 2002 Location: Portland, Oregon
				 | Quote:
 The reason some of like to use Brad Penn is that it is the same oil that, long ago, was sold as Kendall GT. When Conoco bought them out, they changed the formulation of Kendall. Kendall GT has long been considered one of the best oils you could buy regardless of price. Brad Penn continues this tradition.
				__________________ Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic | ||
|  01-01-2014, 01:22 PM |
| Registered Join Date: Nov 2009 Location: Syracuse, NY
|  01-01-2014, 01:52 PM |
| Registered | Quote:
 Here is a pic of the cam of my daily d at just 275,000 miles with a steady diet of Mobil 1 15w-50. Its a 2.2 sohc 4 with 13lbs boost. I currently have Castrol Syntec 5w-50 (for classic cars) but will go with M-1 15w-50 just because.  But OTOH I think its more important to change it often than whether one brand or the other.
				__________________ 87 911 coupe, GP white, cashmere/black 64 Alfa Romeo Giulia TI - the violin 89 Peugeot 505 Turbowagon-other Pcar 67 912 coupe, white, sold 04 Audi Allroad 2.7T | ||
|  01-01-2014, 03:22 PM |
| Registered |
			Sorry the cam pic did not come out as intended....will have to wait till its out of the head.
|  01-01-2014, 03:25 PM |
| Reiver Join Date: Nov 2011
				 | Quote:
 I tried other oils (V1 racing etc.) but they quickly degraded in the heat (oil pressure drop/change after 50 or so miles) whereas BP maintains a constant pressure rate from fill to oil change. I run about 190-195 temp. in that heat and 1 bar at idle. | ||
|  01-01-2014, 03:55 PM |
| Registered Join Date: Jun 2004 Location: Oxford, Ct.
 I don't know Gary I used to see that in the early 80's when all oils used lots of zinc. The oil we used at the dealer (and drained out of said motors) was the Miraculous Kendall
				__________________ 07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car 77 BMW R100S 99 Ducati 996S 04 BMW R1150R DanielJacobsLLC.com | ||
|  01-01-2014, 05:30 PM |
| Registered |
Maybe just luck of the draw then Dan? She's being reground either way..
				__________________ Gary R. | ||
|  01-01-2014, 05:34 PM |
| Registered Join Date: Nov 2001 Location: Santa Cruz, Ca
			I am going to stick with SWEPCO.  It has the prerequisite additives to keep the flat tappets from damage and it can be had at a great price.  Esp if you get a group together and come up with $500 worth in cases.  Shipping is free at that level of purchase.
				__________________ ___________________ Steve- 62 356 S90 Sunroof-sold 11/16  73 911 No longer Targa-3.2L Running GT4 88 Carrera G50 sold 2019 2015 Cayman GTS | ||
|  01-01-2014, 09:44 PM |
| Registered | Quote:
  Hard to tell..the top camshaft has the wear on one lobe (on the toe)..the other lobe next to it has a nice dark area where the lifter (on the heel/ramp) had oil clearance and left a good dark oil stain from the appropriate gap between the lifter and camshaft, like they should. The bottom camshaft looks like it had no clearance on the toe or heel on both intake and exhaust lobes..there is no dark stain on what looks to be the heel/ramp of the lobe adjoining the worn toe next to it. Looks polished all the way around..no dark oil stain. Again..hard to tell without the parts in my hand...my guess...no clearance on the lifter/camshaft on certain valves..some valves were too tight..like zero clearance..therefor wiping the lubricating oil from the camshaft, like on the picture of the bottom camshaft lobes/ramps. Without the .004 valve clearance on all the valves the oil was wiped off the camshaft ramps and wore the hardening off the camshafts..and lifters too. I don't think the camshafts have a zinc problem.The lack of uniformity in the camshaft hardening failure between each set of lobes.I think, most likely (A) the camshafts have a very infrequent valve maintenance problem or (B) heavy duty "racing" valve springs with high valve seat pressures or incorrectly installed stock valve springs with incorrect spring service height with the high valve seat pressures (pounding the valves into the seats and closing up the valve clearances).. or (C) a service tech competency problem or (D) plugged oil camshaft squirter tubes. Last edited by db_cooper; 01-02-2014 at 06:05 AM.. | ||
|  01-02-2014, 05:55 AM |
| Registered |
			Stock motor, never opened or modified, can't speak to valve adjustments...
|  01-02-2014, 06:20 AM |
| Registered |
I wasn't able to find this information for SWEPCO. Can you share your source please. Thanks much.
				__________________ J Mac Current 0 Sold - 67 911T Coupe racecar, 87 911 Cabriolet, 85 911 Targa, 98 Boxster, 95 993 Coupe, 88 911 Cabriolet, 75 911 Carrera #144, modified | ||
|  01-02-2014, 09:14 AM |
| Registered | Quote:
 What engine? 3.2? If all the worn lobes are at cylinders #3 and #6, then maybe an oil pressure problem in the past too.. Those rockers are at the end of the oil squirter tube(s) and suffer damage first when things go wrong, but both camshaft ramps/lobes would be worn..not just one lobe like the camshaft at the top in the picture. Cant tell from the picture which end of the cams we have. | ||
|  01-02-2014, 09:21 AM |
				Swepco
 I live in the SF Bay area and Max is the local distributor. He delivers it free all over the Bay area if you buy the $500. He can be reached at 415-990-6418. Or you can call the company and they will put you in touch with the local distributor.
|  01-02-2014, 09:41 AM |
| Registered | Quote:
 Has anyone information on Swepco 306 regarding their additive package? Our host sells it I just noticed. Thanks all.
|  01-02-2014, 12:14 PM |
				Swepco
			As I recall it is listed in this forum.  You can call or write directly to the company or call Max and he will get it to you. JWE Jerry Woods uses it exclusively in their engines. JWE sells it as well. Bruce Anderson & Jerry Woods' Engine Overhaul Class...
|  01-02-2014, 12:52 PM |
| Registered | Quote:
|  01-02-2014, 02:07 PM |
				 | Quote:
 heard a good explanation. It's always been on stock unopened motors with stock Porsche cams. Maybe a manufacturing issue? I've never seen that particular wear on any other brand of cam ( GM, MB, Cat, Cummins, Deutz, Isky, Elgin, etc,etc)
|  01-03-2014, 04:12 PM |
| Taking it apart is easy Join Date: Nov 2009 Location: rural Quebec, Canada
				 | Quote:
				__________________ Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com | ||
|  01-03-2014, 04:30 PM |
| Registered | Quote:
|  01-03-2014, 04:59 PM |
| Registered |
Porsche makes their own camshafts..I don't think it is a flaw in production or a "zinc" problem..I think the valve(s) ran too tight due to neglected engine maintenance or poor technician skills.
|  01-03-2014, 05:25 PM |
