| Registered Join Date: Jul 2007 Location: Halifax, Canada
			Right now I am leaning towards one of the elf products because it's available locally.
|  10-26-2007, 10:49 AM |
| AutoBahned |
			JBO - I am leery of mixing different oils, esp. from different manfs.! That is b/c you don't know everything in the entire additive package and it is unclear how they will perform in a mix. It is even possible for one additive to interfere with another - a "negative synergy." CN will have a much better read on that however. "head off for Rennsport" -- Charles, have a great trip! And thanks so much for all the work you've done to figure out this conundrum for us all. | ||
|  10-26-2007, 11:01 AM |
| Registered Join Date: May 2002 Location: Portland, Oregon
			WOW, over 14,000 looks and over 300 comments! When I started this thread, I did not think it would get so much "traction". I think we all owe Charles a huge thanks for helping us keep this straight. Seems our chioces are fairly limited but at least they are still there. Quote:
				__________________ Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic Last edited by HarryD; 10-26-2007 at 11:26 AM.. | ||
|  10-26-2007, 11:24 AM |
| Registered |
			I think the Brad Penn and Comp Cams people owe you a retainer.  This thread has been a great resource.  Thanks to all for the input.
|  10-26-2007, 12:09 PM |
| Registered Join Date: Oct 2001 Location: Momence, IL 60954
			Well, my trip for an oil change snowballed. The clutch pedal just didn't feel right - the clutch slave cylinder and line were leaking. Should be fixed before Rennsport though. My wife is taking the friday before and monday after rennsport off so she can drive with me to Florida - I will be set up actually in the Literature meet at Rennsport with Nickies, billet connecting rods, and I'll bring as much oil research with me as I can for those who are there and want to stop and say hi. Ok, off to the post office to do those dreaded international shipments!
				__________________ Charles Navarro President, LN Engineering and Bilt Racing Service http://www.LNengineering.com Home of Nickies, IMS Retrofit, and IMS Solution | ||
|  10-26-2007, 12:14 PM |
				 | Quote:
 If you are going to go through the hassle of having Brad Penn shipped to you, it probably will be cheaper in the long run just to run it straight, rather than blending it.
|  10-26-2007, 01:14 PM |
				 | Quote:
 I would never want to vastly alter the chemical composition of the oil to that degree- if that what it needs to work properly, then you're better off finding a different oil :-) From the SAE papers I have seen, having too much Zn and P won't hurt anything, it just makes reduces the TBN faster as the Zn and P breaks down and reacts with combustion byproducts. I guess having too much Zn and P could also cause deposits to form - that's why the EOS was formulated with an equally healthy dose of Ca to add some detergency.
|  10-26-2007, 01:24 PM |
				 | Quote:
 I'm thinking that blending one manufacturer's product with another of that same manufacturer as long as the viscosities are similar shouldn't hurt anything. Like I said, I've done that before myself.
				__________________ Charles Navarro President, LN Engineering and Bilt Racing Service http://www.LNengineering.com Home of Nickies, IMS Retrofit, and IMS Solution | |||
|  10-26-2007, 01:30 PM |
| Registered |
			my head hurts.  this is an amazing thread.  i am going to look into BG MOA additive to see what it is, and if it has the zinc stuff in it.  i have been running Castrol GTX in my 911's, carb Ferrari's and Lamborghini's for years. i change my oil every 3000 miles or 4 months, whichever comes first. i have friends that are not " net savvy " and they have been devastated to hear about these changes in the oil formulas. they has extensive, and expensive car collections that need to be protected for the future gear heads. i hope the oil companies can hear our typing, and feel our buying power. they need to step up and make something for the older cars, especially air cooled. | ||
|  10-26-2007, 04:31 PM |
Tell me about it :-) I opened pandora's box. Quote:
 Off the forums, an acquantence of Bruce Anderson contacted me recently who wrote to Porsche, in Germany, in German, as he's originally from, and got a load of BS and fluff, dancing around the whole problem trying to make out it's a non-problem. Don't expect an answer from Porsche or the big oil companies any time soon.
|  10-26-2007, 05:26 PM |
| abcdefghijklmnopqrstuvwxy |
			By the way, Brad Penn is a synthetic blend, not just dyno oil.
				__________________ Jay 2010 Spec Iron Mustang NASA GLD #113 (sold)1981 SC Coupe 3.6 (in '74 Carrera clothes) (sold)1999 Spec Miata NASA GLD #113 jaynorthauto.com | ||
|  10-26-2007, 05:53 PM |
			Yup, Brad Penn is 10% Group III.
|  10-26-2007, 06:10 PM |
			Charles. I found a place near by that stocks Elf, swepco, and amsol. Perhaps a few others. Which one would you recommend, what grade, and should the grade change between winter and summer? Currently there is Mobile 1 in there. Thanks! -matt Last edited by old man neri; 10-26-2007 at 06:29 PM.. | ||
|  10-26-2007, 06:26 PM |
| Registered |
			I live in a somewhat isolated area needing to take a ferry to get anywhere and not having Brad Penn or Swepco  available to me without large shipping costs I am leaning towards staying with Mobil-1  as it is  readily available here.The blend I came up with is 7 quarts of 5w-50 Mobil 1 high performance version,3 quarts of Mobil-1 20W-50 V-Twin with a pint of Delco EOS.My rough numbers through Charles tests through Stavely should yield 1222 zinc and 1470 phosphorus.This sounds like a decent compromise.The 5w-50 is 7 bucks a quart but the V-Twin is 17 bucks a quart that is why I was leaning to making a blend.Any comments?
				__________________ Brent Lineker 1975 911S weber conversion. | ||
|  10-27-2007, 05:51 AM |
| Forced Induction Junkie |
			After reading this thread............thanks to all the contributors, btw. I'm using Castrol full Syn 20-50 with two bottles of Comp Cams(each bottle treats 6 qt). The overall first impression is I am amazed how easy the engine turns over to start after spending the night in chilly temps of 40-50 degrees Fahrenheit range. After the disaster I experienced, (see thread; Clogged Spray Bar autopsy ) this information could not have come at a better time. After about 500 miles of driving since the repair, the engine really sings.
				__________________ Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P | ||
|  10-27-2007, 06:57 AM |
| Registered Join Date: Jan 2006 Location: Santa Barbara, CA
			Mobil 1 V Twin at $17 a quart? I think I've seen it for about $11 on the internet. autobarn?
				__________________ jhtaylor santa barbara 74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's. 73 Targa (gone but not forgotten) | ||
|  10-27-2007, 07:18 AM |
| Registered Join Date: Oct 2007 Location: Originally from Orlando, now Halifax, Nova Scotia.
			Wal Mart has the Mobil 1V Twin for 8,42 USD/quart. I mean, who doesn't have a Wal Mart within reasonable dostance? I think Autozone has it for 9 something /quart.
|  10-27-2007, 09:35 AM |
| Registered Join Date: Oct 2002 Location: St. Louis region
			Brent, you can order M1 VITwin online. I just 2 cases (12 quarts) for $113.00 US, shipped.  http://www.avlube.com/index.html
				__________________ Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar. '11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX. | ||
|  10-27-2007, 10:21 AM |
| Registered |
			Do you guys run a 20W-50 in the winter too? I am in Socal so our coldest "winter" temps might hit 35 degrees on the rare occasion but I'd say it's more like an average in the 50s. I currently have 15W40 in the car but I am considering switching it up to a 20W-50 during my fall oil change. I only have about 1500 miles on the last change but I did it in the spring.  I'll look around and see if I can find some M1 V-twin or some of the green oils. I'm very interested in reducing the smoke (higher flash points) and lowering consumption.
				__________________ -Jess | ||
|  10-27-2007, 10:28 AM |
				 | Quote:
|  10-27-2007, 11:42 AM |
