LinkBack Thread Tools Rating: Thread Rating: 26 votes, 3.77 average.
Shaun @ Tru6's Avatar
Thanks Harry.
Jim, yes, if I weren't such a loyal GT-1 buyer for 20 years, I wouldn't even consider it.
I haven't read the whole thread. Is the standard GT-1 available at AutoZone no longer good oil for our cars?
Tru6 Restoration & Design
Old 04-04-2010, 05:07 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1301 (permalink)
3.4 Bigger is better
88-diamondblue's Avatar
Kendall GT-1 is not the same oil as it was when it was produced in Pennsylvania. That said I understood that Kendall GT-1 already had enough ZDDP and now they are saying that there is more ZDDP but it appears to have the same amount as they claimed before. Just a bit skeptical of their marketing on this one.
And the titanium additive? I have not seen any thing on the use of it in oil. Some feed back from those in the know about it would help.
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 04-04-2010, 05:40 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1302 (permalink)
HarryD's Avatar
Originally Posted by Shaun 84 Targa View Post
Thanks Harry.
Based on Peter Z's testimony, I looked up the product data sheet (http://www.conocophillipslubricants.com/documents/kendall/automotive_engine_oils/Ken%20GT-1%20High%20Performance%20MO%20(Ti)%20TDS%20Web.pdf). The data seems to indicate that for the 20W-50 product, we have enough ofhte "good stuff".
FWIW: Our pals at Mobil do not see fit to publish similar data in their product data sheets for their products, only marketing pap.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 04-04-2010, 06:57 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1303 (permalink)
Originally Posted by Jim Garfield View Post
It might be great stuff, but any time I hear phrases like "Liquid Titanium" my anti marketing hackles are raised. The onus is on them to convince me why I need to use their oil, and it better be more than the "Liquid Titanium" advantage.
+1
any adv. with the term "titanium" in regards to performance is suspect, much like the overused term, "turbo".
When Conoco purchased Kendall Oil a few years ago, they kept the packaging but filled the containers with Conoco oil.
The latest Kendall (Conoco) advertising claims the same level of ZDDP and phosphorous as the original Kendal GT-1. However, if so, the market is then limited to older, pre-cat vehicles, thus the doubt.
Sherwood
Old 04-04-2010, 10:43 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1304 (permalink)
cycling has-been
bkreigsr's Avatar
Brad-Penn Racing?
The last two times I picked up a case of BP 'Racing' the containers were marked "High Performance Formulation". The Racing logo still appears several web sites (oilwarehouse), but not on the BP site.
Question - is there still such a thing as BP Racing Oil?
thanks
Bill K
Old 04-05-2010, 03:18 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1305 (permalink)
Thank you for your help Harry, much appreciated.
Old 04-05-2010, 03:47 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1306 (permalink)
Pre Registered
tchanson's Avatar
I'll ask again the question I posted several months ago re Mobil 1 and the ZDDP topic at hand.
The 4-7-09 Mobil 1 information sheet originally shown in post #1266 states that the current formulation Mobil 1 15W 50 has 1,200ppm phosphorus, 1,300ppm Zinc, and is for flat tappet and racing applications.
Those appear to be acceptable numbers, not just "marketing pap".
So, any problems using M1 15W50 instead of the pricier M1 VTwin 20W50 I'm currently running?
Tim
Old 04-05-2010, 06:12 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1307 (permalink)
HarryD's Avatar
Tim
Tim:
I am very aware of the web page you provide the in the link. This is not a Product Data Sheet (PDS) which is dated and has a reference number. A PDS is often used by the customer lubrication engineer to decide which oil producer products are needed lubricate and protect their products. Because of this use, the PDS sheet has a higher status than a table published by a annonymus group.
In the case of Mobil 1, their PDS sheet (Mobil 1 15W-50) is lacking as it does not include Zn, P, detergent, TBN and other critical data. If they are proud of their data, why not publish it? Leads one to wonder, doesn't it?
Harry
2020 MB E350 4Matic
Old 04-05-2010, 06:27 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1308 (permalink)
Pre Registered
tchanson's Avatar
In the case of Mobil 1, their PDS sheet is lacking as it does not include Zn, P, detergent, TBN and other critical data.
I understand the distinction re a PDS. However, the information sheet in question is not published by an anonymous group, but instead on the Mobil site itself. It's either true or not.
Agreed that a PDS would be preferable, but given the wide availability of M1 15W50, perhaps a simple Blackstone analysis of a current batch would be worthwhile to verify Mobil's stated numbers, if they are in doubt.
As one of many former M1 15W50 "red cap" users here, it would be of interest to verify if we can go back to it after the "Extended Performance" 15W50 formulation misstep.
Tim
Old 04-05-2010, 07:00 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1309 (permalink)
dshepp806's Avatar
I agree that a virgin (independent) analysis would be in order (I'd use two labs, as well). I may do this when I renew my Staveley's agreement.
Doyle
Tim
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 04-05-2010, 11:10 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1310 (permalink)
Wash. State
nesslar's Avatar
I never saw anything more on the John Deere Plus 50 Diesel Motor Oil....the specs. looked good. Any further word on this stuff? Lar
Old 04-05-2010, 12:10 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1311 (permalink)
HarryD's Avatar
Turbos!
Today I received a PM for a guy who was overwhelmed by the oil threads.
He asked a simple question, what oil for my turbo? I am not sure BP or SWEPCO is the best due tothe heat the oil sees in my Turbo. I want to use Mobil 1 for it's heat resistance but the ZDDP Issues has me worried. What should I do?
Well, I certainly do not know but I will bet that someone here does. Can we help him out?
Harry
2020 MB E350 4Matic
Old 04-11-2010, 04:42 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1312 (permalink)
GaryR's Avatar
Send a message via ICQ to GaryR
Mobil 1 V-Twin 20w50, best of both worlds though I believe even regular M1 15-50 has suitable ZDDP.
Gary R.
Old 04-11-2010, 04:46 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1313 (permalink)
Zddp
What year is the turbo? ie. Does it have flat tappet valves?
Who says M-1 has the required ZDDP?
The last time M1 dropped the levels, they told nobody and many got burned and lost engines.
I for one will never let M1 cross my path ever again.
___________________
Steve- 62 356 S90 Sunroof-sold 11/16
73 911 No longer Targa-3.2L Running GT4
88 Carrera G50 sold 2019
2015 Cayman GTS
Old 04-11-2010, 05:45 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1314 (permalink)
Has anybody used or looked into using aircraft oil such as phillips 20-50w X/C or aeroshell 20-50. These are designed for air cooled lycomings and continental engines and i use phillips in my pitts biplane and it takes some serious abuse!.Just wondering as i just bought an 84 911.
Old 04-12-2010, 06:44 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1315 (permalink)
Green Earth Oil
There's a new green oil.
It's biodegradable, made from animal fats here in the USA, and rinses off your hands with water.
Gunnar Racing is using it in their new LMPC Oreca in the ALMS.
The prototype race car has a 430HP Corvette motor and they finished second in class at the 12hrs of Sebring and won the LMPC class yesterday at Long Beach.
They are saying it is better than synthetic and you can pour it out on your lawn if you want.
Maybe this stuff is the future...
Green Earth Technologies
Green Earth Technologies - G-OILŪ - G1 Racing Oil
Historic Performance By G-Oil's Green Earth Team Gunnar :: PaddockTalk :: F1, Formula 1, NASCAR, IndyCar, MotoGP, ALMS, And More!
News > Sebring: Green Earth Team Gunnar comments on IMSA decision - Motorsport.com
Old 04-18-2010, 09:00 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1316 (permalink)
GaryR's Avatar
But what's this all about?
"WARNING:
Too slick for aluminum engines.
DO NOT USE."
Gary R.
Old 04-18-2010, 09:08 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1317 (permalink)
AutoBahned
RWebb's Avatar
Originally Posted by JFairman View Post
They are saying ...you can pour it out on your lawn if you want.
that would ONLY be true for unused oil - in fact, all new motor oils are rel. nontoxic
used motor oil - of any type - will always contain heavy metals (from wear on bearings, etc.) & combustion byproducts
ALL used motor oil needs to be treated as a hazardous waste (which it is) - recycle at an approved facility (County Transfer site, aka "dump") and avoid prolonged skin contact
Old 04-18-2010, 10:33 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1318 (permalink)
UNDER CONSTRUCTION!
carrera turbo's Avatar
with out reading the entire thread does anyone know if these aircraft oils will work well in our cars. im in alaska and dont have brad penn up here. but alot of the aero shell etc. tons of small aircooled planes moving around up here.
thanks guys for any help.
cheers ed
Sometimes the first thing that comes to mind should be the last thing that you do!
Old 04-18-2010, 12:13 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1319 (permalink)
Someone must have researched this before.....?
I have a comment that one should consider. Piston aircraft engines typically run a very limited RPM range. Full throttle take offs might be 2500 rpm. Cruise is more like 2000-2200 rpm. Our engines run over a much wider range of RPM and torque. I'd have to assume that aircraft oil is formulated for this range.
Don
72T Coupe - SOLD :-(
Old 04-18-2010, 12:28 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1320 (permalink)
