Have you seen this thread?
http://forums.rennlist.com/rennforums/showthread.php?t=407224 On page 5, someone mentioned “failures on brand new factory race engines with the recommended Mobil 1 fill.” My question is how can you blame this on the oil? If the oil really caused a brand new motor to fail, wouldn’t every other motor with the same oil fail too? There are bunches and bunches of motors running tens of thousands of miles just fine with the factory recommended M1. Isn’t it possible that something else caused this brand new factory race engine to fail?
Downshift |
I made up my mind to go with Brad Penn 20W50 racing about 25 pages ago. I still had this strange compulsion to read the read to its end.
For those in the Denver area, Hill Petrollium in Arvada carries Brad Penn motor oil. I talked with Norm Fisher (sales manager), 303-424-6262. He noted the strong advocacy for BP oil in the Porsche community, Pelicanites in particular. He quoted me $41.00 per case. I will be stopping by later this week to pick up a couple of cases (on the way to pick up my targa top from Dave Brown in Boulder).
96 993 Cab, 73E Targa, 72S Targa |
If that's 12 quarts to a case, thats an incredibly good price.
I just wonder if the Brad Penn will turn to carbon coke in the heat of a 930 turbo bearing-housing. Thats why I stay with synthetic oil with plenty of zddp. |
Dixie Region R Gruppe
I use Brad Penn and I could not be happier.
Instagram @phillipkj4 1980 911 SC Backdated Viper Green 1992 Ferrari 348TB |
Where are people ordering Mobil 1 MXT 10-40 and V-twin Motorcycle oil from?
I ordered a case of the MXT but it was over $100 is there any place cheaper? I'm thinking I should switch to BP for the summer months, but not sure what to use for the winter when I want protection down to 0 degree F. That's why I was planning on running the MXT all year round. Works out to the same price (1 change per year vs. 2 times per year). Any reccomendations?
Current Drivers - 2006 BMW 1 Series & MB E320 Wagon (new addition 1998 Mazda Roadster) EX - 1993 Porsche 911 Carrera 2 EX - 1979 Porsche 911SC TARGA EX - 1976 BMW 2002 |
Large Registered Member
You might consider Redline Oil. I just made the switch! They make their version of Motorcycle VTwin in 10W30, 10w40, 20w50, AND 20W60. I've spoken to a Rep., and they do have and will maintain the higher levels of Zn & P in their motorcycle oils. They will be lowering it though in their regular automotive line. For info, check out www.redlineoil.com . The nice thing for me is that my local Napa Store stocks the entire line of Redline Oil Products.
'85 Carrera Coupe, Marble Grey #118 JP/R6 '93 Lexus SC400, '00 Ford F-150 '70 911T- 2.7 (SOLD) |
Charles,
I'm trying to make head or tails of this whole thread. Thanks for all of the hard work. I use synthetic because I've been told they are more stable at higher temps. Is this sound reasoning? Do the dino oils you like perform as well as the synthetics in this regard? I haven't been overly concerned about the new lower ZDDP levels because I run my track-only car under 2,000 miles a year. Should I reconsider? I run a multi-viscosity with the heavy end being 40 weight. I've read that you should run the thinnest oil that gives you sufficient oil pressure because there's less parasitic loss due to the thicker oil. I believe it also moves heat faster/easier. This is why I choose 40 over 50. What are you're thoughts on this? Thanks.
'83 SC |
Read through this whole thread and haven't seen any mention of High-Temperature/High-Shear (HTHS) numbers for Brad Penn or the rest of the brands discussed.
From the Porsche Club Great Britain forum: High-Temperature/High-Shear by Simon This test is a simulation of the shearing effects that would occur within an engine. In fact, it's actually designed to simulate motor oil viscosity in operating crankshaft bearings. Under high stress conditions where shearing can occur, the VI Improvers (polymers) break down. As they do, the viscosity of the oil decreases. This is what the High Temperature/High Shear test checks for. The HT/HS test is measured in Centipoise (cP) as the Cold Crank Simulator test is. However, in this case, because you're hoping for the least loss of viscosity with an increase in heat and stress, you want the cP value to remain high. Each SAE multi-viscosity grade has a specific lower limit for the HT/HS cP value. If a multi-viscosity oil cannot achieve a cP value above that limit, it cannot be classified under that viscosity grade. For instance, according to the SAE specifications, an oil must achieve an HT/HS cP value of 3.7 or higher in order to be classified at the 15w40 viscosity grade. The thinner the oil the lower the number. Comparisons of HTHS numbers. Here for comparison sake are a few numbers that we have compiled from data sheets and requests to the oil companies concerned. These are well known oils and considered to be "quality" synthetics so these comparisons are relevant. Silkolene PRO S 5w-40 HTHS 4.07 Motul 300V 5w-40 HTHS 4.51 Silkolene PRO S 10w-50 HTHS 5.11 Motul 300V 10w-40 HTHS 4.19 Silkolene PRO R 15w-50 HTHS 5.23 Motul 300V 15w-50 HTHS 5.33 Mobil 1 Motorsport 15w-50 HTHS 5.11 Castrol RS 10w-60 HTHS 3.70 |
From a similar thread at Rennlist (http://forums.rennlist.com/rennforums/showthread.php?t=407224):
Just because you feel all your questions pertaining to this subject are answered doesn't mean everyone else's are. |
In the dyno testing we've done, there really is no justification for running a lighter oil for more HP. We have not seen large, if not any, parasitic losses from internal friction because of higher viscosity oils in areas where hydrodynamic lubrication (bearings) would be susceptible to this kind of HP losses. This was even going to an extreme of testing Xw20 oils versus 20w50 oils. I wouldn't necessarily say there really isn't any gains over a 15w40 friction modified oil versus similarly formulated 20w50. Same goes for synthetic versus non-synthetic; we just did not see any HUGE differences. Now if the engine had tighter clearances than the typical aircooled engine, that might be a different story.
Charles Navarro President, LN Engineering and Bilt Racing Service http://www.LNengineering.com Home of Nickies, IMS Retrofit, and IMS Solution |
I've seen that number quoted. It's wrong; the data sheet says MIN 3.70, but it's actually in the low 6.0s. It's a shame this oil has been reformulated, it was a decent oil where the need for a 60 wt when hot was required while still allowing for cold start protection down to 0F or lower!
I'm having trouble finding info on Quaker State Q synthetic Euro formulation. I would imagine it's designed to meet the VW standard but I wonder what the ZDDP is like on that product.
Maybe I'm missing something obvious but when you first started this thread your web page had a listing of the levels of a long list of oils you tested. I can't find that list anywhere. Did you take it down?
'83 SC |
Yes, I took the list down for a few reasons. I kept getting emails that it was out of date OR people were saying there's nothing wrong with an oil, ignoring the fact that the listed results was for the previous formulation (no longer existing), among other reasons.
Did you ever test Quaker State's Q Euro blend?
'83 SC |
Luis: Yes, I know 30+ pages is very long but ths is a topic close to religion for many. I would hope your questions are answered as well. If not, please do ask. After all, a question not asked is rarely answered. Regards.
Does anyone know if the oils targeted for high mileage engines (75k+) contain the Zn & P levels needed for better protection??
jp |
Charles:
Since the list was taken down for the above mentioned reasons, can you recommend an oil for a higher mileage engine (911-3.2)? 'Possibly a dino & syn type oil?? Which high mileage oil presently available?? jp |
Charles in looking for a good 10W-30 oil for my '91 Miata, that is mostly street driven with some AX use, I started using the Brad Penn 10W-30. Any reason to think that this l would not be of the same quality as the 20W-50? I know this engine does not put the same loads on the cams as my 911, but I have to believe the BP additives and base stock couldn't hurt.
rickdm '87 Carrera '91 Miata '78 SC (ex) |
