| Troy Join Date: Jul 2011 Location: Circleville,Ohio
			Is it a myth that air cooled engines should use a straight weight oil and not a multi grade engine oil. I dont know where but I have always thought that a straight weight was the best for air cooled. Can somebody give an explanation
|  08-06-2011, 12:01 AM |
| Air Medal or two Join Date: Jul 2003 Location: cross roads
			I am going to guess it comes from a time when there was NO such thing as 20/50 .I think it hit the market late 70s. I put it in my Harley when every one said t would blow up (At that time Harley recomended streight 50 wt!) I never blew, and history shows all is well with 20 / 50 even in P cars
				__________________ D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between | ||
|  08-06-2011, 02:38 AM |
| Registered Join Date: Jun 2004
Yep, me too for my '86.  Actually, I'm not terribly brand loyal to Shell - with as tight as the specs have gotten, any of the API CJ-4 15W-40 oils are essentially interchangeable.  Lately, I've been using Motorcraft's version since it comes in a 5 qt bottle vs. 4 qt that all the other CJ-4 oils are packaged in.
				__________________ Brad | ||
|  08-06-2011, 04:49 AM |
| Registered Join Date: Jan 2004 Location: Docking Bay 94
			The "Straight Weight" must be an old recommendation. When I was living in Socal in the mid '80s, there was a  VW/Porsche garage (Foreign Motors in Temple City) that suggested I use Castrol straight 30 in my '68 VW. I can't imagine they would still say that now, I think that shop is just Honda-Toyota these days.
				__________________ Kurt | ||
|  08-06-2011, 07:14 AM |
| Registered |
			Rotella T was the factory fill oil on new 911s back in the day..it was the reason they had a "Shell" sticker on them when new. Nothing exotic..good old fashioned HDEO oil. Still use Rotella...great oil. | ||
|  08-06-2011, 08:24 AM |
| Registered Join Date: May 2002 Location: Portland, Oregon
				 | Quote:
 Back in the day, single weight motor oil may have been the way to go, but as of 1984, Porsche moved clearly to the 20th century with the use of multigrade oils. See below for a page from the owners manual.
				__________________ Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic | ||
|  08-06-2011, 06:16 PM |
| Registered Join Date: Apr 2008 Location: Bolivia
			Straight weight oils are stuck in the minds of old-timers who can't change their thinking. A 10W-30 will consume less oil than a 30. It will also have more HP. I touch briefly on that in my oil paper (just updated) Selection of the right oil
				__________________ Taking care of Cars and Industry in Bolivia Richard's Corvair Selection of the Right Motor oil for the Corvair | ||
|  08-28-2011, 06:43 AM |
| Registered Join Date: Nov 2001 Location: Santa Cruz, Ca
			I'm and old timer and I use to use straight weight back in the 60's.  Most Porsche folks are pretty adept at following the changes in technologies. We even know how to use a mouse along with our computers.
				__________________ ___________________ Steve- 62 356 S90 Sunroof-sold 11/16  73 911 No longer Targa-3.2L Running GT4 88 Carrera G50 sold 2019 2015 Cayman GTS | ||
|  08-28-2011, 06:54 AM |
| Registered Join Date: Nov 2007 Location: USA
				 | Quote:
 Marketing? Partner promotion & relationship management? Technical differences? What gives? Pontification by webbies w/o REAL details? Official recommendation vs. optimal? What gain does the PCA get out of touting the official Porsche recommendation? How can opinions on this board be so emphatically different?
				__________________ '88 911 Coupe (sunroof delete) / FRP/Carbon Front Fenders & Bumpers / Elephant Racing Suspension / 3.4L Motor Conversion | ||
|  08-29-2011, 05:38 AM |
| Registered Join Date: Sep 2009 Location: North of You
				 | Quote:
 There are thousands of oils, some people choose to research and choose what they think is the best compromise (all oils have some degree of compromise) and some prefer just to continue using 'what has always worked'. As long as there are different oils you will have different opinions....
				__________________ "A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." | ||
|  08-29-2011, 06:41 AM |
| Registered Join Date: Jul 2001 Location: Portland Oregon
				 | Quote:
 Opinions vary due to differing experiences,.......
				__________________ Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com | ||
|  08-29-2011, 07:02 AM |
			PCA ? they dont know anything anyway ! Pass the cheese pleasz
|  08-29-2011, 07:21 AM |
| AutoBahned |
			well, I would not go that far also, PCA was the "distribution center" for all sorts of esoteric Pooschey knowledge before the internet came along | ||
|  08-29-2011, 11:20 AM |
| Registered Join Date: Jul 2000 Location: So. Calif.
|  08-29-2011, 11:27 AM |
| Moderator |
			The first big oil controversy which occurred back in the early 70s was weather to use the new fangled 20w-50 oils that were coming out at the time, turns out they were fine but Castrol GTX did get a bad rep from this era.  Prior to this straight 30 was the most commonly used oil. Next oil controversy was the Dino vs Synthetic latest is the ZDDP controversy. For long emissions systems life ZDDP levels have been reduced and for better economy lighter wt oils are used. ZDDP is an anti wear agent indicated for use where there are high loads, as in flat tappet cams. Since modern cars don't have flat tappets and since the manufacturers are on the hook for 10 yr emissions warranties they will recommend modern low ZDDP low viscosity oils and it is just easy for them to back date this recommendation as they get to sell more parts when more engines wear out. Doesn't mean it's the best oif for your car. Owners of older cars should avoid oil w/ the starburst seal on it as this is the sign of low ZDDP, low vis. oil If you can get it there are several good 20w-50 or 15w-50 oils w/o the starburst seal that are available, my favorites are M! 15w-50 and Brad Penn 20w-50
				__________________ Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | | ||
|  08-29-2011, 01:15 PM |
| AutoBahned |
			I now avoid anything with the word "Castrol" on it based on comments from Steve W. Brad Penn, Swepco, and VR-1 are all known to be fine so I use Brad Penn in the 911, and VR-1 (cheaper) in the VW Vanagon. | ||
|  08-29-2011, 02:13 PM |
| Registered |
I'm sure this is buried in this thread somewhere, but I just checked and VR1 has slightly more zinc and phosphorous than Brad Penn, although they are really close.  I use VR1 because it is readily available around here.
				__________________ Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes | ||
|  08-29-2011, 02:18 PM |
| AutoBahned |
			by "useful thoughts" you mean something other than the expert opinion of one of the top Porsche race car shops in the US I guess. what exactly are you looking for?? | ||
|  08-29-2011, 02:50 PM |
| Registered Join Date: May 2003
			I've been using Blackstone labs for oil analysis on my airplane for a few years now.  You could send them a virgin sample of the oil to test the zinc and phosphorus levels.  Maybe run 5 quarts in your daily driver for a few months and then send in a sample.  This would get you the oil information and the engine health of your daily driver.  -Andy
				__________________ 72 Carrera RS replica, Spec 911 racer | ||
|  08-29-2011, 03:37 PM |
| AutoBahned | Quote:
 I gave the answer I had. You might want to just move along and use whatever you want or go thru Charles Navarro's site or even do a search here. | ||
|  08-29-2011, 03:48 PM |
