AutoBahned
The post indicates that a change from VR-1 to Kendall GT-1 eliminated low-speed chain slop from the pressurized chain tensioners at elevated engine temps. Not discounting his experience, but that's one for the anecdotal library. Sherwood |
Penrite Zinc Level Chart
For the Aussie crew or in fact anybody that can get this oil. Here is a zinc table listing showing PPM.
I use HPR 40 in the SC. TECHNICAL BULLETIN NO: 192 LATEST ZINC LEVELS Issue: November 2011 PRODUCT SAE GRADE API RATING ACEA RATING JASO ZINC PPM HPR 0 0W-30 SL/CF A3/B4 1050 HPR 5 5W-40 SN/CF A3/B4 1050 HPR 10 10W-50 SN/CF A3/B4 1140 HPR 15 15W-60 SN/CF A3/B4 1140 HPR 30 20W-60 SM/CF A3/B3 1110 HPR 40 25W-70 SL 1450 HPR 50 40-70 SL 1450 HPR GAS 10 10W-50 CI-4/SL A3/B3 1220 HPR GAS 20W-60 CG-4/SL 1290 HPR DIESEL 5 5W-40 CI-4 PLUS/SL A3/B4 1220 HPR DIESEL 15 15W-50 CI-4 PLUS/SL A3/B4 1220 HPR DIESEL 20W-60 CH-4/SJ A3/B3 1220 PREMIUM FULL SYNTH 0 0W-50 SN/CF MA 1250 PREMIUM FULL SYNTH 5 5W-60 SN/CF 1200 PREMIUM FULL SYNTH 10 10W-70 SN/CF 1200 RACING 0 0W-20 SL/CF 1320 RACING 5 5W-30 SL/CF 1320 RACING 10 10W-40 SN/CF MA 1240 RACING 15 15W-50 SN/CF MA 1240 RACING 20 20W-60 SN/CF MA 1240 ENVIRO+ 0W-40 SN/CF C3 890 ENVIRO+ 5W-30 670 ENVIRO+ 5W-40 SN/CF C3 890 ENVIRO+ C4 5W-30 C4 510 ENVIRO+ DL-1 5W-30 C1/C2 DL-1 510 ENVIRO+ GF-5 5W-30 SN RC 850 EVERYDAY DRIVING 5W-30 SL/CF MA 1080 EVERYDAY DRIVING 10W-30 SL/CF MA 1080 EVERYDAY DRIVING 15W-40 SL/CF-4 MA 1080 EVERYDAY DRIVING 20W-50 SL/CF-4 MA 1080 STOPS OIL BURNING 30-70 SJ 1110 MARINE 4 STROKE 10W-50 SL MA 1320 SMALL ENGINE MONO 30 SG/CD 1170 SMALL ENGINE MULTI 10W-30 SL/CF A3/B3 1140 SMALL ENGINE MULTI 20W-50 SG/CF 1170 RUNNING IN OIL 15W-40 SF/CC 1610 http://www.penriteoil.com.au/tech_pdfs/192%20LATEST%20ZINC%20LEVELS.pdf
Goose- "nothing a year in the tropics wouldn't fix" |
Mixing VR-1 20-50 with Kendall GT-1 in 20-50
Not trying to create conflict, it's just that Autozone only had 7qts ($3.29) of VR-1, so I grabbed 4qts of Kendall GT-1. I'm thinking the add-pacs are very similar, if not the same, and the base oil has to be identical (20-50). 'Just wanted to check whether mixing these two oils would pose a problem...
This is for an oil change in a '84 3.2 911. Thank you, jp NY |
I wouldn't do it. What makes you think the base stock is the same? Even if they are the same, the signature in oils is all in the additive package. I would bet (but I do not know for sure) that the add package is different.
Anyway, just a cardinal rule that a lot of folks have, stick to one oil and one oil only. Mixing is just sacrelige and should only be done on a must do basis. Just my opinion, I am not a tribologist.
"Simplicity is supreme excellence" - James Watt |
I wouldn't hesitate to add a quart of some off-brand oil to top off the car in a pinch. I wouldn't mix as much as 30-40% or more of a different brand though. The blends can be very different.
Kurt |
It won't kill the engine, but you won't get the full performance of either. It isn't the base oil that has to be compatible, (and all are), but the additive packs are completely different. No problem with clash, just not the benefit of the zddp of the VR1 when you dilute it with the Kendall.
BTW, I just noticed someone posted a Kendal oil analysis here a couple of years ago with an ISO cleanliness code of 22/19/14 Motor oils need to be 18/16/13. That sample had 19,000 particles per ml more than the limit (over 4 microns) that will continue to cycle through the engine because the typical oil filter will take out about 50% of the 20 micron particles on each pass. The most damage is done by the 5 to 12 micron particles since they are small enough to keep circulating but big enough to cause problems. Here is a chart that shows the code in 100 ml levels, indicating that 22/19/14 between 2 million and 4 million particles per 100 ml over 4 um. ![]()
Taking care of Cars and Industry in Bolivia Richard's Corvair Selection of the Right Motor oil for the Corvair |
abides.
Three years ago I had a virgin oil analysis performed on Brad Penn. The ISO value was 23/22/17.
A similar test on Kendall (the formula before "Liquid Titanium") yielded an ISO value of 22/19/14. I wonder if this is a lab issue.
Graham 1984 Carrera Targa |
Taking it apart is easy
Oh man, I'm getting a headache. The more we look at this whole oil thing, the more conflicts, surprises, disappointments, and confusion there is.
If there is one perfect oil, we evidently haven't found it yet. Anyway, tomorrow the oil companies will change their additive formulations and all of this thread will be obsolete. It seems to me that if an oil is carefully chosen and generally meets the performance criteria spelled out here, then just use the stuff. I don't believe the engine will blow up from any one of many different oils out there. Is this issue being beaten to death?
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com |
AutoBahned
maby if its dead long enough it will become the best oil
82 SC , 72 914 |
So you Still Think "oil is Oil"!
I saw this today: Leapin
This is exactly the problem with the newer oils. This type of failure was unheard of prior to the SM oils.
I'm looking at buying a car and had an oil analysis do. The report said all normal,, but the copper and iron look high. Does anybody know what numbers would be normal for the copper and iron?
james www.gruppe9autowerks.com Its not how fast you go...its how you go fast |
The oil report typically has some normal unit averages, at least some I've seen. How high were the copper and iron in PPM? What engine?
AutoBahned
The oil report doesn't say what the normal range is. The report is tucked away at the moment but I do recall that copper and iron were significantly higher than everything else. I'll see if I can't dig it out in a few minutes.
I found that interesting, but oils change all the time. Anyway, what about cleanliness of other oils? How do we go about getting that info?
This is an example of a problem oil report for a 3.4 Porsche 911..maybe a problem or not. The four quarts of make up oil in 6500 miles is a question too. Were the unit averages and metals like these? Notice the ZDDP numbers are 800ppm or less on the Mobil 1. A more robust oil would be a good idea, with around 1200ppm Z+P. Last edited by db_cooper; 05-18-2012 at 02:04 PM.. |
says:
alu 5 chro 8 copper 34 iron 23 lead 4 tin 7 sil 15 potas 2 sodium 23 moly 163 water 0.1 oxidation 8.2 vis 13.6 gly ND fuel <2% tbn 6.2 nitration 4.4 soot 0.3
What were the zinc and phosphorus numbers? Should be in the neighborhood of 1200ppm.
Yes the iron and copper were high. Use an HDEO (Rotella, Delvac, Kendall Super D) or Brad Penn if you are using an automotive oil with low Z+P. Do an oil analysis again in the next 4000 miles. |
