To my way of thinking, many of these changes have reduced to safety margins for lubrication and wear protection (which are are not warranted by the car makers to the extent emissions control systems are ).
Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic Last edited by HarryD; 05-08-2023 at 10:06 AM.. |
Plus we don't do endurance events. Generally Time Attack format. What confuses me somewhat is that the clearances are quite tight which would call for a lighter visc oil than I've used in the past. But the company says to go up 2 levels of visc for E85 racefuel and forced induction. If I go off their chart for Alu block and steel rod with operating temps of 160-220f then it points to an oil with a viscosity that scares the living daylights out of me. Luckily they say to bump up two grades but coming from using a 25w/60 or straight 60 racing oil in the past it looks a little concerning. I think taking all those factors into consideration, it's pointing towards their 20w/50 XP6. Thanks for any consideration/expert opinion Charles. ![]()
Patrick Youtube 333pg333 86 modified 951 Last edited by 333pg333; 05-09-2023 at 11:57 PM.. |
For an aircooled engine, we recommend Driven DT50 for the street and XP6 for the track, so that lines up with what your engine builder said. Driven's chart doesn't take into consideration that an aircooled engine needs thicker oil viscosities than watercooled ones.
Charles Navarro President, LN Engineering and Bilt Racing Service http://www.LNengineering.com Home of Nickies, IMS Retrofit, and IMS Solution |
PCA Member since 1988
333pg333: I'll save you the trouble. They recommend the DT50 for air cooled engines. It even says so right on the label. Rationale is that air cooled engines run hotter becuase they don't have the temp control of liquid cooling, so run a thicker oil. However, in that discussion, I specifically asked about the DT40, because I had recently rebuilt my engine and knew I had tight bearing clearances, .002 on rods and mains. Their catalog recommends oils based on several factors, including bearing clearances. They agreed that I could use the DT 40 instead.
I ordered the DT50 this time, but I have plenty of oil pressure, so next time I will go with DT40. Oil FLOW is what cools bearings and other parts of the engine, so as a general rule, you should run the thinnest oil that builds sufficient oil pressure without any cam/follower wear. Charles, FYI on the response I got from Driven about both DT50 and DT40.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! Last edited by PeteKz; 05-15-2023 at 11:37 PM.. |
Thanks Gents. My engine is a watercooled i4 968 race motor. At the last dyno it made 618whp @ 16psi however it soon after suffered catastrophic failure from the block cracking due to the serts the then US builder used. We've gone down a different path with this engine. Luckily the crank, rods, pistons, cams were all reusable. However the new builder hasn't given us the exact oil visc to use. Rather given us the chart and the build details. It narrows the choices down but not the final answer. Hopefully I'll hear back from Driven's Tech dept. I shall fwd their recommendations to this thread.
Patrick Youtube 333pg333 86 modified 951 Last edited by 333pg333; 05-10-2023 at 04:30 PM.. |
fwiw...they (Gibbs/Driven) came back and suggested GP-1 15w/40. I replied asking why not XP6? Still waiting on response.
Patrick Youtube 333pg333 86 modified 951 |
After reading a bunch of this thread it seems like there are a few 99% solutions but I’m not sure the context where they might be really required. I get it that a 99% solution would perhaps be warranted on some cars. Where would just getting a few jugs of Mobil 1 fall in the scheme of things for a decent condition semi daily driver?
The previous owner of my car (‘83 SC) was using Mobil 1 and, until reading this thread, was inclined to just do the same. |
Regardless of what they emailed, I'd stick with the oil and viscosity recommended by your engine builder. My recommendations for both aircooled and watercooled Porsche engines can be downloaded here: https://lnengineering.com/education/technical-library/free-download-engine-oil-quick-reference.html
"Patrick, I chose the GP-1 15W-40 for a couple of reasons. The 15W-40 is a better fit for your main bearing clearance, your front and rear bearings were a bit tighter than the rest, but I would recommend going to the heavy side in line with the center mains. I did not consider the XP for your application because the XP has very little detergent and virtually no corrosion protection package. XPs are formulated for applications that are disassembled and inspected after every event. Thanks, Dean" So I'm glad he actually looked at the data sheet I sent him and made a thoughtful decision. What do you think of this Charles?
Racer
My race engine went over 70 hours with Driven XP6. There was no sign of corrosion in the engine and is was quite clean....
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
Thanks for that Scott. What motor?
Racer
A high compression 3.6L 964-based air-cooled engine. I run leaded race fuel in it.
I will again state that you should go with your engine builders recommendation of XP6 if that is what he is recommending. If you are insistent on running a 40wt, use XP9 over GP-1. I would advise doing used oil analysis though and actually compare how each oil performs in your engine for how it is being used.
I discussed this with the builder again and we've settled on the XP6. It will either be the 15w/40 or 20w/50. I might even keep both on hand for the dyno. If the 40 shows overly high pressure drop when coming off load then we would switch to the higher viscosity. I appreciate your input Charles. I took a look on your site. Interesting link to the break in procedure by that bike engine builder.
Is VR-1 on sale somewhere?
1984 911 Carrera Coupe - 32C #73 - M64/05 1998 E36 M3 4dr 2006 Sienna 5dr - the hauler 2004 Lexus GX470 2010 Cannondale Caffeine II - Lefty |
ED Sully posted this elsewhere and I think it has has good info:
Still here
latest VR1 spec sheets....
![]() ![]() That "expiration date" must be some kind of inside joke being played by these oil companies on the consumer. |
Some millions of years in the earth becoming oil must be drained and discarded from your sump within a year...
