What to check next? Headlights out
Replaced the turnsignal switch and the headlight switch (although with an older one).
On the dash I have the highbeam blue light on, but no high beams or low beams no matter where the turn signal switch is. Parking lights and turn signals all work.
What can I check now? I did check the fuses as well.
www.akalikoskateboards.com
72 3.0 RSR flared Targa
Old 10-03-2007, 10:17 PM
Administrator
Jack Olsen's Avatar
There are four or five plugs at the firewall under the dash -- they connect the wiring for those switches through to the trunk. It's easy to knock them out or knock them loose, and you need to get under there with a flashlight to find them.
Old 10-03-2007, 11:10 PM
HarryD's Avatar
Does the dash switch turn the headlights on and off or are they always on?
Is the blue light aways on or only when your flash the hi beams or switch them on?
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 10-04-2007, 05:25 PM
probably a bad TS switch. HL switch gives power to TS switch, TS switch to the fuses and then fuses to the lights. see if there's power at the fuses.
206 637 4071
Old 10-04-2007, 06:26 PM
