What to check next? Headlights out
Replaced the turnsignal switch and the headlight switch (although with an older one).
On the dash I have the highbeam blue light on, but no high beams or low beams no matter where the turn signal switch is. Parking lights and turn signals all work. What can I check now? I did check the fuses as well.
www.akalikoskateboards.com 72 3.0 RSR flared Targa |
Administrator
There are four or five plugs at the firewall under the dash -- they connect the wiring for those switches through to the trunk. It's easy to knock them out or knock them loose, and you need to get under there with a flashlight to find them.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Is the blue light aways on or only when your flash the hi beams or switch them on?
probably a bad TS switch. HL switch gives power to TS switch, TS switch to the fuses and then fuses to the lights. see if there's power at the fuses.
