Would that not be a 930 Slant?
88' 930 03 Tacoma, 04 Duramax, 06 R350 Benz If you are traveling at the speed of light & turn on your headlights, does anything happen? |
HI Akila,
this mechanism and motor look exactly like mine. Did you have a chance to find the source for this motor. If you do, please let me know. I am looking for one. Thanks.
Fat butt 911, 1987 |
These are the RX-7 Motors. I have not set them up as of yet, but the motors are readily available on Ebay. Let me know if I can assist further.
Akila,
Thanks for response. Do you know which year is this one? I saw many Mazda motor on ebay but they are not exactly the same (the 3 mounting points). Also, yours look so new. Do you know any place to get it new? Thanks
Don't know where to get new ones. I had picked up an extra set just in case I need parts. IIRC these are the latest year with the rectangular headlights. I bought a complete assembly of Mazda's, but I forget what it cost.
Do you remember what year is the one on your pics, above?
Dont recall. I will go dig em out later & look for a part #.
Here are a picture of the actual motor from the slant fender. Hope this helps
I have exact same motor, which doesn't work anymore, and I don't know what year it is from.
Thanks Akila.
For some reason I have 87' to 94' in my head.
Akila,
no... umm... I don't know exactly what year but those on ebay posting 86-90 are not the same as this one. The 3 mounting bolts are not mounting to the body but they have arms.
This look like what you are looking for. Click on the small picture.
http://www.********.com/catalog/raframecatalog.php?carcode=1192250&parttype=1412&a=FRc1192250k920901
So it looks like out motors came from the first generation RX-7. The year selected for the ******** website was 1982.
Also, I found out there was a fat & skinny motor. Apparently the ones to use are the skinny ones. 1979-1985
Look like that what it is. Thank you Akila.
It's RX7 from 83 to 85. I ordered and installed it in. The headlight works now.
Thanks Akila, thanks all.
Would you happen to have a wiring diagram of your lights?
My car was premade that way, with the same motor. I didn't change anything, just cut and reconnect exactly how it was before. I didn't even have to do any measurement because all wires are the same collor. Sorry don't know how to help. If you can think of any way I can, let me know.
mazda motors, RX 7 early version. when installing them in a porsche, take care to seal the relays completely with silicone as they are mounted upside down from their original position. Otherwise these relays fill with water, corrode and fail
the swivels/ hinge points need to be lubricated periodically too
1970 914-6 street"evil cockaroach" 1970 911 Targa "ST" Jade Green IROC Tribute (ready to race) |
TRE, I'll keep that in mind, if & when I ever get around to mounting the Slants.
rnln, Where did you end up buying the motors, price?
