Cold Start Problems
I am having trouble starting my 3.3 when it is cold, it winds over for a while and won"t fire after leaving it for 5 minutes it usually starts and runs fine.
I have replaced the switch in the cover are there any other tests I could try?
Old 09-10-2007, 05:32 PM
Member 911 Anonymous
DRACO A5OG's Avatar
What Year!
'85 Carrera Targa
PCA/POC
Old 10-02-2007, 04:52 PM
Wer bremst verliert
JohnJL's Avatar
Could be a fuel priming issue. When its cold try turning on the key to "run" for 5 seconds before trying the ignition. If that doesnt work try first turning the key to run for 5 seconds (not to "start" yet) then off, then to "run" again for 5 seconds, then try the starter.
Could be caused by a bad accumularot (if you have one) or dirty/tired fuel check valve allowing fuel to drain back to the tank.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 10-02-2007, 05:05 PM
