Bypass AC controls to test AC system
Is this possible? My fan speed knob is rusted in the off position, and im sure even if i could get it to turn, the contacts are too rusted to make electrical connections. Can i bypass the switch in anyway to make sure it's only the switch failing the system?
Old 10-02-2007, 10:32 AM
Is the switch RUSTED in the off position, or was it FRIED in that position by overheating or a short? Assuming that you have the switch exposed, you can disconnect the wires and jumper from the single hot wire to each of the three wires (one at a time!) that control which speed is selected. The hot wire is a big red one. Use a voltmeter to determine which one is hot and which is ground, and protect the hot one until you're ready to start the process.
Old 10-02-2007, 04:43 PM
It definately looks rusted. I will try that, thanks for the help!
Old 10-02-2007, 05:13 PM
