-   -   RSR Conversion - Part 2 - The build (http://forums.pelicanparts.com/porsche-911-technical-forum/370496-rsr-conversion-part-2-build.html)
wachuko 12-14-2012 08:55 AM
I had a spare brake caliper decal... makes the 5.00 license plate look a lot better :)
http://i151.photobucket.com/albums/s...ps2e05c755.jpg
Also made some exhaust tip covers and painted those black, to avoid getting the bumper dirty... Need to adjust them, just some quick photos
http://i151.photobucket.com/albums/s...psb1457400.jpg
http://i151.photobucket.com/albums/s...psc365e13d.jpg
http://i151.photobucket.com/albums/s...ps90362bdd.jpg
wachuko 12-27-2012 02:49 PM
Baby steps... baby steps side mirrors...
http://i151.photobucket.com/albums/s...ps05890045.jpg
Baby steps... baby steps front slip spoiler...
http://i151.photobucket.com/albums/s...ps8b51cc57.jpg
I will pick them up Saturday and do the install sometime next year, lol...
http://i151.photobucket.com/albums/s...ps40d75d7f.jpg
wachuko 12-28-2012 01:30 PM
Got some small parts that I misplaced (and will sure find after I do the install) for the sunroof air deflector... now I need to find out how the heck these are installed... :confused:
http://i151.photobucket.com/albums/s...ps1a29d0c2.jpg
puffinator 01-05-2013 01:57 PM
LED license plate light
Thanks for the tip. I just finished an RSR backdate project was stumped on how to create license plate lights without drilling holes where I didn't want them. I saw your thread, ordered the lights and just finished installing them. They work great and no additional holes!
wachuko 02-08-2013 12:51 PM
If all goes well, by the end of next week, the car should be done...
They are fixing the small paint details we found, installing the front lip, side mirrors, finishing fitting of the headlights, fuel filler setup, front fender side mesh, and install of side scripts.
http://i151.photobucket.com/albums/s...psd288423b.jpg
http://i151.photobucket.com/albums/s...ps5b8e5703.jpg
aerodyn930 02-08-2013 04:38 PM
Can't wait to see it in person, Great job guys, :)
Lou
DaddyGlenn 02-08-2013 05:32 PM
Like to see your car and Jeremy's running side by side at Sebring. Any chance of that?
wachuko 02-11-2013 04:03 AM
At some DE, sure!! But our car is not setup for hardcore racing... Jeremy would be running circles around us, lol.
Once the body is done then we have to drop the engine and tranny to clean it up, paint the engine bay, fix the crushed oil lines (using the pressured air method), change oil seals, injector boots, go over the brakes...
But I want to take it to the track for DEs... SmileWavy
Some photos from the fuel filler build...
http://i151.photobucket.com/albums/s...ps8b7dc8d1.jpg
http://i151.photobucket.com/albums/s...ps6ec7fc89.jpg
DaddyGlenn 02-11-2013 07:01 AM
Originally Posted by wachuko (Post 7266496)
{snip}... fix the crushed oil lines (using the pressured air method), ...{snip}
I am very interested in this. Can you provide some info on how this is done? I've got a few good indentations in mine and was thinking of just replacing them.
wachuko 02-11-2013 09:08 AM
Sure, here you go:
Fixed my Crushed Oil line for $5 and a beer.
Imcoz 02-11-2013 09:35 AM
subscribed. Nice work!!
wachuko 02-11-2013 05:43 PM
Now with water drain and sealer...
http://i151.photobucket.com/albums/s...ps37e7cdf4.jpg
Side mirrors are also finished...but I will install those since I left the bolts at home, duh!
gsmith660 02-13-2013 05:37 PM
I like that any specs on how you did it
wachuko 02-16-2013 11:42 AM
Fuel filler done!
http://i151.photobucket.com/albums/s...ps1ac6ca44.jpg
Still need to replace the rubber hose with a flexible one as the 90 degree one that I got was not a perfect fit...
http://i151.photobucket.com/albums/s...ps1d57956f.jpg
wachuko 02-16-2013 11:48 AM
To make the drain/water catcher it is just using a cheap bowl as the mold. Fiber glass over a bowl. Once dry, remove the bowl and you get a nice FB piece. Wish we would have left it in raw fiber glass... But it got painted the same color as the tank.
Then we cut the stock filler pipe just to use the section where the cap screws on. Some epoxy to glue it to the fb bowl, some seam sealer. Weld two bracket to hold it at the brake base, one 90 degree bent rubber hose and voila!
gsmith660 02-17-2013 04:13 PM
Where did you pick up the cover you mounted on the hood
wachuko 02-17-2013 06:42 PM
From a Mustang... :eek: :)
gsmith660 02-18-2013 07:42 AM
So I could pick one up at summit racing then thanks
wachuko 02-18-2013 09:57 AM
Correct. Ours came from a Mustang, so we had to grind the logo on the inside of the lid...:D
gsmith660 02-18-2013 06:11 PM
One last question did you flange your hood
