Best way to tell if my '86 has Bilstein Sports front
Recently bought the car and am in the process of doing the entire suspension over. Was told the car had Sports front and rear. Definitely Sports rear, but is there an easy way to tell in the front? Want to send them out to be revalved for my 23/31 torsion bars as long as the fronts are in fact Sports. TIA
Ed '86 911 Coupe (endless 3.6 transplant finally done!) '14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one) '97 BMW 528i (the sensible car, bought new) '12 Vintage/Millenium 23' v-nose enclosed trailer |
From what I understand, if you are going to send them out to be re-valved, it does not matter what you start with. For my coil over setup, the struts I started with had HD shocks, but they were valved to work with the higher spring rates I'm using. I'm not a Bilstein expert, but I think the main difference in the HD and Sport shocks are the valving they have from Bilstein.
If I'm wrong will someone please skool me.
John Snodgrass 1973 Porsche 911 "Barney" (race car for sale) 2008 Nissan Maxima - Daily Driver 1999 F350 Diesel Crew Cab - Tow Beast 1990 Airstream 36' Land Yacht - Home Away From Home |
Actually, I believe that the Sports are also shortened (Stroke). I know that Bilstein will also shorten your shocks as part of their service. I elected not to have them do this, as my car is at Euro height and they didn't recommended it.
Gone but not forgotten - 1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C |
