wheel fitment
Hi all I have some 17" ROH wheels I was using for intermediate rains they
measure 8.5 and 7.5 with a backspace of 6.5 and 6" I was using them with spacers on a 86 3.2 . What car do you think they were designed to fit? I tryed them on a 930 but the sit way inside the fenders I was thinking 993 or 964. the reason I ask is so that I can sell them . Thanks Palmer |
Is there an "ET" number stamped inside? That would answer a lot of questions.
No there is no ET size stamped on the wheels. Palmer
According to your backspace numbers the 8.5 has a 44mm offset (+/-) and the 7.5 has a 57mm offset (+/-). These would probably fit a 993 but are pretty narrow.... They may also fit a 87 and later 944,951,968 etc and possible the 964. Not sure on the rear fitment but the fronts should fit.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Are you reporting overall width or rim width(aka bead width)? ![]() also was backspace measured as indicated in the diagram?
Well, if that is overall width (which I had not considered) the rears are 69.8mm (+/-) and the fronts are 69.8mm (+/-).....
Never heard of anyone building/buying Porsche wheels that are 6.5/7.5 in width though... Cheers
The wheels have (17"J 8.5" )cast into the rears and (17" J 7.5) into the fronts. I measured the back space with a strait edge witch was 6.5" and 6" Thanks Palmer
w/o knowing the flange width, which I estimated to be .5" I get +45ET for both wheels
If the flange is smaller the ET goes up, but only a very small amount. I've got no idea what they might fit other than an SC/Carrera w/ spacers. 964 wants ~55mmET which you can't get out of a 45 w/ spacers
Yes, you are correct, I messed up my math on the smaller wheel....
Cheers
Bill I think the flange is .5 I was using them with 1" spacers on the rear and .750 on the front
with long studds with 255/225 tires sorry to be a pia I just want to sell them to the right person.Palmer |
Schleprock
My guess is 928 fitment. The ROH ZR wheels seemed to be popular for 928s from what i've seen.
Kevin L '86 Carrera "Larry" |
