Sorry but ? on tire size on a 7 fuch
I know we have beat this in the ground lately but I have been questioned about my front tire size order.
I'm going with (as suggested by several members of this board) 205/50/16 on 7's for the front and 245/45/16 on 9's on the rear. Just to verify will the 205's strech and fit on my 7's?
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
cycling has-been
no stretch involved. 7's and 205's are a perfect fit.
Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
Bug Eating Member
205's fit just fine. The upper end of tire width for 7" wheels is probably 225.
I run 225/50 's on my SC on the front
1982 SC |
what everyone said, also, I belive that for the few carerras that Porsche equiped with 7's and 8's, they used 205 50's on the front 7's, straight from the factory.
Schleprock
205/50 is going to be shorter than the standard 205/55. Theoretically one inch shorter in overall diameter. So what you'll end up with is a tire that has a thinner sidewall in the front than in the rear. Probably not too noticeable front tire vs. rear tire. But what you will probably notice in the front is you'll have a larger gap between the top of the tire and the fender lip.
Don't get me wrong, i'm all for shorter sidewalls since I think the typical sizes in 16 inch for the 911 have rather fat sidewalls. A 205/50-16 does well to reduce the fat sidewall issue. Problem is, there's not an equivalently short rear tire size, other than a 225/45-16, which is rather rare to find. In my opinion 17 inch tires are much more appealing to the eye, have better size selection and perform better relative to sidewall stiffness.
Kevin L '86 Carrera "Larry" |
I have 205's on my front 7's. No issues.
