I'm a loser, baby.
oregonmon's Avatar
Going to replace clutch cable do I need this too?
My clutch squeaks (not that big of a deal) and is pretty stiff it probably is time to change the clutch cable right? It's a 79 SC and I'm sure the original.
Reading a couple posts guys were saying it made a lot of differrence and I'd hate to get stranded when it goes POP!
Do I need to replace the $35 clutch spring? Is this what people call the helper spring? I see it listed for the Turbo, same for the SC?
1979 911 SC
Old 10-17-2007, 10:20 AM
Tired Member
DaddyGlenn's Avatar
The clutch helper spring is pretty easy to replace...unless you've got some rust holding it to the pin like I did (PITA). I'd change the bushings, too. You might want to look at your pedal assembly while your at it. No personal experience, but I understand the pedal bushings wear out and can cause issues.
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 10-17-2007, 10:34 AM
I'm a loser, baby.
oregonmon's Avatar
Is it just the one bushing? Either bronze or plastic?
1979 911 SC
Old 10-17-2007, 10:39 AM
I'm a loser, baby.
oregonmon's Avatar
I see that the spring is unavailable, kinda unsure if I need to replace. Any thoughts, would like to order these parts today.
1979 911 SC
Old 10-17-2007, 12:44 PM
jtfreels's Avatar
I would also recommend rebuilding the pedal cluster. I used the wevo bronze set, cause that is what the PO had bought and never put in.
Regarding the omega spring, I would check the bearings around the pin, mine were obviously crushed with pieces missing.
2002 Boxster Speed Yellow
Old 10-17-2007, 02:15 PM
Grappler
Rodsrsr's Avatar
+ one on rebuilding the pedal assembly. Its very common for the roll pin down at the pedal to shear off, dropping your clutch pedal to the floor. The big spring at the pedal is pretty robust, so it should be ok. The omegas get a little worn. New cable, rebuild pedal assembly with bronze bushings, and new omega, and you should have no problems.
Old 10-17-2007, 03:54 PM
Moke81's Avatar
Read the tech article from our host on clutch cable install. I also recommend the 101 projects book. The most difficult part was getting the helper spring off. I used my dremmel and cut it off.
_____________
1981 SC Coupe
Old 10-17-2007, 04:15 PM
